HMS Prince of Wales
    October 2005
HMS Prince of Wales
Posted by scottmh59 on Friday, January 11, 2008 4:27 PM
How close is the body of the prince of wales to the uss Texas?Is it close enough to use it and modify it to an early Texas?Any thoughts would be great..thanks in advance..
Posted by Dreadnought52 on Friday, January 11, 2008 5:17 PM
about as close as an apple to a banana. it just isn't suitable. WS
    May 2006
Posted by David Harris on Friday, January 11, 2008 5:26 PM
Assuming that you mean the King George V class one, not very I would have thought. The Prince of Wales hull is/was the best part of 200 foot longer &  was a bit wider in the beam. That is before you even start thinking about hull contours.
    April 2005
Posted by ddp59 on Friday, January 11, 2008 9:56 PM
scott, use an arizona hull as that is what i'm doing. am using the 426 scale arizona with about 1.5" cut out of her length to get to the right length.
    October 2005
Posted by scottmh59 on Saturday, January 12, 2008 3:31 PM
what about the uneven deck of the arizona,compared to the texas?How will you handle that?
    April 2005
Posted by ddp59 on Saturday, January 12, 2008 6:51 PM
i built up at the step area towards the stern, marked off on the end of the stern for proper height then used a stationary belt sander with fine grit sandpaper to give me a slope from bow to stern.
    July 2003
Posted by ridleusmc on Sunday, January 13, 2008 12:23 AM
I took some pics of the Texas about a year ago.  Maybe you could use them.
http://smg.photobucket.com/albums/v491/ridleusmc/USS%20Texas%20BB-35/
Semper Fi,
Chris
