1/12 Atomic City Mercury Friendship 7 - COMPLETE!
    August 2008
Posted by Astrazoic on Monday, June 15, 2009 5:52 PM
Hopefully, the pictures that will be included here, combined with some narrative, will be useful to those who are building the 1/12 Atomic City Mercury kit. I found very little online in terms of what others have done with this kit, and it has been difficult translating the Mercury Familiarization Manual with available photos to make sense of the interior mess of cables and components. I will post photos as I go along...
http://www.philsmith.us/Mercury1.JPG
http://www.philsmith.us/Mercury2.JPG
http://www.philsmith.us/Mercury3.JPG
http://www.philsmith.us/Mercury4.JPG
http://www.philsmith.us/Mercury5.JPG
http://www.philsmith.us/Mercury6.JPG
http://www.philsmith.us/Mercury7.JPG
http://www.philsmith.us/Mercury8.JPG
http://www.philsmith.us/Mercury9.JPG
http://www.philsmith.us/Mercury10.JPG
http://www.philsmith.us/Mercury11.JPG
http://www.philsmith.us/Mercury12.JPG
http://www.philsmith.us/Mercury13.jpg
http://www.philsmith.us/Mercury14.jpg
http://www.philsmith.us/Mercury15.jpg
http://www.philsmith.us/Mercury16.jpg
Phil Smith
www.astrazoic.com
    August 2008
Posted by Astrazoic on Tuesday, June 16, 2009 12:36 AM
More developments - all batteries are now in place. Some relays and inverters have also been added to the right side. Finally, I added a floor, which features heel and toe guards (the latter fashioned using spare B-52 bomb tips) and will eventually serve as the base for the periscope and instrument panel.
http://www.philsmith.us/Mercury17.jpg
http://www.philsmith.us/Mercury18.jpg
Each of the knobs you see on these boxes will have a cable attached to it, which will be quite the drama...
Phil Smith
www.astrazoic.com
Posted by Aurora-7 on Tuesday, June 16, 2009 9:59 AM
Looking very nice. The first five images, however, do not work.
I've seen a few images of this kit down up in exqusite detail. I really should get this kit, considering my avatar and username.
    August 2008
Posted by Astrazoic on Friday, June 19, 2009 2:30 PM
A few more additions this evening, including the instrument panel camera.
http://www.philsmith.us/Mercury19.jpg
http://www.philsmith.us/Mercury20.jpg
Phil Smith
www.astrazoic.com
    August 2008
Posted by Astrazoic on Monday, June 22, 2009 12:35 PM
Finishing up with various component boxes. The remaining components, located in the bottom sections, are environmental equipment, mostly tubes, pipes and so forth.
http://www.philsmith.us/Mercury21.jpg
http://www.philsmith.us/Mercury22.jpg
I also started on the instrument panel, which in the case of Mercury must be built up on both sides because the backside is exposed when the hatch is removed. I primed the subassembly to see how things are going. Next, I will paint the multicolored sections, then add knobs and toggle switches. Final bits will be decals of each gauge, clear covers for each, and stenciling.
http://www.philsmith.us/Mercury23.jpg
http://www.philsmith.us/Mercury24.jpg
Phil Smith
www.astrazoic.com
    July 2007
Posted by mallagoodee on Tuesday, June 23, 2009 10:49 AM
Phil, did you use the kit instrument panel and just augment it, or are you scratchbuilding the entire interior?
You're doing such clean, precise work ... I'm loving this!
Thanx lad
Pete
    August 2008
Posted by Astrazoic on Tuesday, June 23, 2009 12:38 PM
Thanks, Pete. The entire interior is being scratchbuilt, it seems, including the instrument panel. The panel in the kit is inaccurate, and is too thick in profile...
Phil Smith
www.astrazoic.com
    February 2007
Posted by PetarB on Tuesday, June 23, 2009 8:24 PM
Looking forwards to seeing more on this WIP!
It's not until you see the actual components through something like this excellent kit, that you realise the kind of low tech used to originally send people up into space. Having said this, it's not all that different these days, in some respects!
www.studiostarforge.com
    February 2005
Posted by rokket on Sunday, June 28, 2009 1:50 AM
Very detailed and professional work! Anxiously awaiting more!
AMP - Accurate Model Parts Fabric Flags, AM Uboat Goodies & More http://amp.rokket.biz/
    August 2008
Posted by Astrazoic on Thursday, July 2, 2009 9:33 AM
Added the pitch, yaw, and roll indicators and the clock insturment to the main instrument panel.
http://www.philsmith.us/Mercury25.jpg
http://www.philsmith.us/Mercury26.jpg
Phil Smith
www.astrazoic.com
    August 2008
Posted by Astrazoic on Sunday, July 5, 2009 1:18 AM
New developments. Added the final component to the main instrument panel - the navigation aid with globe.
Also added the right console, which includes, among other things, manual engagement of RCS. The toggles, pull rings and some knobs will be added after painting. These insturment panels are multicolored and will present a significant painting challenge, so I left some of the complex switches off until later.
http://www.philsmith.us/Mercury27.jpg
http://www.philsmith.us/Mercury28.jpg
http://www.philsmith.us/Mercury29.jpg
http://www.philsmith.us/Mercury30.jpg
Phil Smith
www.astrazoic.com
    August 2008
Posted by Astrazoic on Sunday, July 5, 2009 10:50 PM
The main instrument panel is complete, except for some random knobs and pull rings that will be added after painting. Added this evening is the auxiliary panel, which is on the astronaut's left. This panel was a bit of work, to be sure...
I also added these cool hex-nut pneumatic fittings (the silver things), which are apparently aftermarket accessories for armor. These are attached to the pull rings (which will be added later) - the astronaut pulled or pushed these rings to enable or disable his ability to manually control the RCS system. The rings were literally attached to tubing that led directly to the thrusters.
http://www.philsmith.us/Mercury31.jpg
http://www.philsmith.us/Mercury32.jpg
http://www.philsmith.us/Mercury33.jpg
http://www.philsmith.us/Mercury34.jpg
A good deal of this detail will, in fact, be obscured when the model is complete. However, there are four reasons why I am adding so much detail:
1. I love to do it and practice is always good
2. I will photograph the completed assembly before it is inserted into the capsule
3. Depending on the angle of view through the hatch and window, it is very possible cutting a corner will be apparent, and I just can't stand that Smile
4. I'm learning a lot about my subject matter
Next up: Periscope and instrument panel mount
Phil Smith
www.astrazoic.com
    January 2003
Posted by veedubb67 on Wednesday, July 8, 2009 5:14 PM
Phil,
As usual, your work is impeccable! Thanks for sharing. Hope to see it in person soon.
Rob
Iwata Padawan
    August 2008
Posted by Astrazoic on Saturday, July 11, 2009 12:58 AM
The instrument panel mount and periscope housing is more or less completed in terms of construction and priming. The things that are missing are a few handles and a casement for navigation documents which will go on the front part of the housing facing the astronaut.
Again, the main reference for scratchbuilding has been NASA's Mercury Spacecraft Familiarization Manual, which contains detailed drawings of all spacecraft components.
I also test fitted the assembly with the aft bulkhead and seat and stuck the whole hing into the capsule to make sure averything fit ok. So far, so good...
I am finally approaching the painting stage, though this will be complicated by the addition of wiring harnesses...
http://www.philsmith.us/Mercury35.jpg
http://www.philsmith.us/Mercury36.jpg
http://www.philsmith.us/Mercury37.jpg
http://www.philsmith.us/Mercury38.jpg
http://www.philsmith.us/Mercury39.jpg
http://www.philsmith.us/Mercury40.jpg
So far, this has been an absolute joy to build!
Phil Smith
www.astrazoic.com
    August 2008
Posted by Astrazoic on Tuesday, July 14, 2009 8:02 AM
Added environmental greebly. The open-ended pipe will lead to a ribbed flexible hose that ends up behind the instrument panel for cooling purposes:
http://www.philsmith.us/Mercury42.jpg
http://www.philsmith.us/Mercury43.jpg
I also modified the floor opening for the persicope, which from now photos indicates a square feature surrounded by small junction boxes:
http://www.philsmith.us/Mercury44.jpg
Phil Smith
www.astrazoic.com
    August 2008
Posted by Astrazoic on Thursday, July 16, 2009 10:27 AM
Painting of the instrument panel has begun. As those who are familiar with the Mercury Program know, the instrument panel was color coded using Earth tones. It is rumored that John Glenn was responsible for this, but there is no confirmation that is true.
In any case, it is a major challenge to airbrush these sections, as I expected. But I did not want to paint the panels before gluing all the switches on, because the glue could mar the finish. On the other hand, I could not paint the assembly with all the switches in place. So I had to make a compromise.
So far, so good. I will just need to do some very minor touchups with a brush at the end. I expected much worse...
http://www.philsmith.us/Mercury45.jpg
http://www.philsmith.us/Mercury46.jpg
When I complete the basic painting of the panel, I will describe the colors used for those interested in building a model of the Mercury.
Phil Smith
www.astrazoic.com
    March 2004
Posted by subfixer on Thursday, July 16, 2009 11:37 AM
I wonder why it was earth tones. Maybe because it was easier on the eyes in the harsh natural sunlight?
You are doing a superb job on this, Astrazoic. My compliments.
I'm from the government and I'm here to help.
    August 2008
Posted by Astrazoic on Friday, July 17, 2009 12:33 AM
Basic painting of the instrument panel is complete. What remains are the periscope display, knobs and switches. Next, I will affix decals, which include analog dials and stencils. Finally, I will add clear plastic disks in each dial. Once done, I will paint the other side and begin the process of adding the wire harness.
http://www.philsmith.us/Mercury48.jpg
Following is the same image, but with paint colors used. All paints are Polly Scale acrylics over Tamiya Gray Primer. Mix ratios are unclear - I eyeballed it, mostly because different photos show different values. I aimed for "close enough" here.
http://www.philsmith.us/Mercury47.jpg
Phil Smith
www.astrazoic.com
    August 2008
Posted by Astrazoic on Monday, July 20, 2009 9:21 AM
Made some progress on the instrument panel. The panel and periscope alone constitute a model, it seems. I'm still far from finished with this assembly. By far, the most difficult, or the most frustrating, are the toggle switches and transparent toggle guards.
The dials are decals made from diagrams of the panel itself from the NASA Mercury Familiarization Manual. Clear plastic disks will eventually be pushed into the circular recesses.
I also successfully printed out some stencil decals for all the switches. Application of these decals is going to be an adventure, to be sure.
http://www.philsmith.us/Mercury49.jpg
http://www.philsmith.us/Mercury50.jpg
Phil Smith
www.astrazoic.com
    March 2004
Posted by subfixer on Monday, July 20, 2009 1:34 PM
    February 2007
Posted by Buckeye on Tuesday, July 21, 2009 1:05 PM
Very nice work there!
    May 2007
Posted by RTimmer on Tuesday, July 21, 2009 2:56 PM
Simply outstanding!  I have this in my stash, and I only hope when I get around to it that I am able to do even a fraction of job you're doing.  Thanks for continuing to share your progress.
Out of curiousity, what printer are you using for decals?  What decal stock for printing?
Cheers, Rick
    August 2008
Posted by Astrazoic on Tuesday, July 21, 2009 6:26 PM
Thanks, gentlemen!
Decal stock is the Testors kit (I threw away the container that held the paper). I used the Testors decal bonder to seal the decal film. The printer I use is a Hewlett Packard HP Photosmart 2610. I used PowerPoint to adjust the size of the diagram and printed directly from this document. I'm too lazy to muck around with the images in Illustrator or Photoshop :)
Phil Smith
www.astrazoic.com
    July 2009
Posted by german plastic model rocket builder on Wednesday, July 22, 2009 5:30 AM
The first class your work to here. respect! Thumbs Up [tup]
Greetings from Germany,
Thomas
Posted by Aurora-7 on Thursday, July 23, 2009 7:10 AM
Amazing work on the instrument panel.
    November 2003
Posted by Mike F6F on Thursday, July 23, 2009 5:57 PM
Using my best Michael Dorn Klingon voice, "Impressive!"
"Grumman on a Navy Airplane is like Sterling on Silver."
    August 2008
Posted by Astrazoic on Friday, July 24, 2009 2:43 PM
Thanks, my friends. I'll be posting some pictures this week of the finished assembly.
Phil Smith
www.astrazoic.com
    February 2005
Posted by rokket on Friday, July 24, 2009 9:09 PM
reeeallynice work, love to see true miniatures, can't wait for more! Oh, several posts back, love that logic (4 reasons) for including obscured detail.
    July 2009
Posted by Pedro Neto on Friday, July 24, 2009 10:52 PM
Amazing the construction..... all in scratch? Cool! Where did u get the blueprints?
[]´s
    August 2008
Posted by Astrazoic on Friday, July 24, 2009 11:54 PM
Thanks!
This has been my main resource:
Project Mercury Familiarization Manual (November 1961):
(http://ntrs.nasa.gov/archive/nasa/casi.ntrs.nasa.gov/19740076527_1974076527.pdf)
Phil Smith
www.astrazoic.com
