1/12 Atomic City Mercury Friendship 7 - COMPLETE!
    July 2009
Posted by Pedro Neto on Saturday, July 25, 2009 11:44 AM
Thanks man... very good the article.... I´m building for now a AMT kit of the Nasa rockets..
[]´s
    August 2008
Posted by Astrazoic on Wednesday, July 29, 2009 11:00 AM
Added some additional knobs and switches. I also added the charts holder to the front. Two fabric sacks will be attached to this, and I will be making a tabbed notebook to go in the silver chart holder. I'm almost done with the periscope viewer, and I anticipate the entire assembly being done this week. I also added a bunch of rivets to both sides of the instrument panel mount, since I found some excellent photos of this online recently.
http://www.philsmith.us/Mercury51.jpg
http://www.philsmith.us/Mercury52.jpg
Phil Smith
www.astrazoic.com
    July 2009
Posted by Faith 7 on Thursday, July 30, 2009 4:01 PM
 Hello,
I think that you are doing such a great job on your mercury capsule. I'm doing one of Faith 7 and was wondering if I can pick your brains a bit?
I was wondering how you are doing your rivet detail. I never done this before and would really like to know so as to improve my model. Also what method to you use to make all the batteries/inverters etc? I'm in awe over the ammount of detail you are doing it's not an easy task to decipher the famillarization manual and then compare it to photos!
    August 2008
Posted by Astrazoic on Friday, July 31, 2009 2:53 PM
Thanks for the compliments and the questions. I look forward to seeing your Faith 7!
Rivets are made by cutting disks from the thinnest rod size available from Evergreen Plastic. Think of slicing a sausage, and you'll get the idea. I then pick up each with a sharp X-Acto knife, lightly "spearing" it, if that makes sense. I touch the disk to a bit of adhesive (cement if going on plastic, superglue if going on painted surface), then affix it to the desired location. It's tedious, but goes by surprisingly quickly when you get the hang of it.
The various components, including the batteries, were made with Evergreen sheet plastic. Basically, I just made a bunch of six-sided boxes (some components were a bit more than that, of course). I sanded these down and primed them. Small components were cut from solid square or rectangle rod stock.
The references are great, but I confess that my objective is to get the model around 75% accurate to the real thing. The documents are used as a baseline for construction, because the actual vehicles were modified and adjusted with time, deviating from the specs. I figure "close enough" works - like an impressionist painting, I suppose. I want to capture the essence of the Mercury Program in a model - cramped, cluttered, analog, scary, damn-the-torpedoes, all-or-nothing, spam-in-the-can...
Phil Smith
www.astrazoic.com
    July 2009
Posted by Faith 7 on Friday, July 31, 2009 4:01 PM
Hello.
Thanks for answering my questions. I will now be able to do rivets! I'm basically doing a simillar approch to the ammount of detail. As long as it looks "cluttered" and has the basic differences i think it's ok otherwise I could get very bogged down trying to get it perfect. I have found the mercury maintenance manual helpfull as it gives you more of an impression of how the thing goes together! I only have the 1959 version but it's still good if you are looking at the major componants.
I look forward to seeing your model progress. It's exciting!
    August 2008
Posted by Astrazoic on Saturday, August 1, 2009 1:57 AM
You're welcome!
Finally got around to adding the periscope screen. I also added a flight booklet (or whatever) and two small fabric bags to the front of the booklet holder. I'm not sure if this is accurate, but it does look like some sort of fabric bags or something are attached to the book holder in some photos.
The screen is composed of several layers of clear plastic and a few sheets of clear yellow plastic; the intent is to provide a sense of depth. The reticles are simply scribed lines in the plastic.
I'm just about ready to move to the back of the instrument panel. It is clear to me that the instrument panel is the most labor intensive part of the model, but there is a long way to go before completion Smile
http://www.philsmith.us/Mercury53.jpg
http://www.philsmith.us/Mercury54.jpg
Phil Smith
www.astrazoic.com
    March 2004
Posted by subfixer on Saturday, August 1, 2009 4:21 AM
     What is better than superb? Whatever it is, that panel defines it.
I'm from the government and I'm here to help.
    August 2008
Posted by Astrazoic on Tuesday, August 18, 2009 10:24 AM
I made good progress on the complex plumbing associated with the nitrogen pressurization system. What a pain in the neck this was! The tanks themselves are wooden balls I found at Michaels. The rest of the assembly consists of copper wire and plastic components. The pencil line represents the extent of the floor, and the shaded square the location of the periscope and instrument panel mount.
The box is the tape recorder.
Next up: The window and hatch frames, rivets and other assorted greebly.
http://www.philsmith.us/Mercury55.jpg
Phil Smith
www.astrazoic.com
    July 2009
Posted by Faith 7 on Tuesday, August 18, 2009 2:58 PM
Wow I always get so excited when I have found that you have posted new pictures!
Your work is amazing and an inspiration! I can't wait for more. I havent worked out how to post photos on this website otherwise I would be posting some of my Faith 7.
By the way I've been doing the rivets the way that you suggested and It's been working great.
It makes such and improvement to the model Thanks!!Thumbs Up [tup]
    August 2008
Posted by Astrazoic on Wednesday, August 19, 2009 12:45 PM
Faith 7 -
Thanks, and I look forward to seeing photos of you build. I was disappointed when I started this project to find so few online images of this model built. So many asked for it and bought it, but few are contributing to the pool of experience online, which would be helpful.
You can get a free Flickr account and post pictures, then provide links here.
I'm glad that the rivet thing is working. It doesn't seem practical to do this, but the experience proves otherwise.
Phil Smith
www.astrazoic.com
    July 2009
Posted by emertko on Friday, August 21, 2009 9:59 AM
Unbelievable work!
Thanks very, very much for sharing it!
I hope I can do something half as good!
Very best regards
Enrique
    August 2008
Posted by Astrazoic on Sunday, August 23, 2009 9:38 AM
Thanks, Enrique :)
A little more progress this weekend. I added window frames and rivets to the window opening in the hull, discarding the two clear parts that come with the kit. The window itself is quite complex, but after studying Mercury drawings it makes sense. I also added a major rib with rivets, some assorted greebly, a condensation tank (the curved box) and a mount for the window pole and flashlight. I think the window pole is used by the astronaut to open and close window filters and a mirror (both of which will be added later), as both it and the flashlight have cords to prevent them from floating away in microgravity. The astronaut is also not able to reach certain things easily.
http://www.philsmith.us/Mercury56.jpg
http://www.philsmith.us/Mercury57.jpg
I also discovered the perfect concave dome for the forward pressure bulkhead - the opaque dome from one of those easy mount press-on/press-off lights that you stick in closets and whatnot. Armed with that, I built up the bulkhead with the circular hatch. I got lazy with the center disk, which has a more complex shape in reality. I figured what I came up with is close enough Smile
http://www.philsmith.us/Mercury58.jpg
Phil Smith
www.astrazoic.com
    July 2009
Posted by Faith 7 on Sunday, August 23, 2009 6:40 PM
Hi Astrazoic!
Great work as usaual! You are defiently braver than I was with the window!
I have a flicker account now but posting pictures here still does not seem to like me. I put the URL in the appropiate line in the images box but no preview comes up.
Well here is a link to my flicker page, I only have one photo on it at the moment but will post more soon. Chose to finish the exterrior so I could put the observation window in.
http://www.flickr.com/photos/41701767@N02/3843870814/
Regards
P.s I will start my own thread soon.
    August 2008
Posted by Astrazoic on Monday, August 31, 2009 12:11 AM
Just about finished with the interior walls of the capsule, having added three lights (note that the light fixture in the middle is non-functional, because the other two are bright enough - the astronaut could control each light anyway), the right-hand console, the manual actuation system for roll, pitch and yaw, a cooling hose, and assorted components. The red wire will be hidden, ironically enough, with wire harnesses. Electrical checks and physical test fitting between the capsule hull and the aft bulkhead was completed with no issues, and priming of the hull will take place tomorrow. I figured I would photograph stuff before priming in case it helps folks build similar structures for their Mercury builds.
http://www.philsmith.us/Mercury59.jpg
http://www.philsmith.us/Mercury60.jpg
http://www.philsmith.us/Mercury61.jpg
Phil Smith
www.astrazoic.com
    July 2009
Posted by Faith 7 on Monday, August 31, 2009 3:27 AM
Nice work once again. I like the idea of working lights, makes it more 'moody' I think.
I was going to ask you what dia. the helium spheres are? I think the ones I got are the wrong size.
I'm looking forward to see how you wire and plumb everything up as this is one area that is confusing me a little, to know which is connected to which.
Keep up the good work.
    July 2007
Posted by mallagoodee on Monday, August 31, 2009 5:48 AM
I just can't get over the level of detail you're including Phil!
The rivets in the band midway up the interior look perfectly spaced ... those hinged struts look like they're adjustable ... the different layers in the window ... what a visual treat!
The bands around the spherical tanks are what ... Styrene? And the tanks themselves, are they wood?
And thanx for posting before applying primer ... seeing the different types of materials is what inspires me.
I was kinda hoping to see your Shuttle at the Columbus NATS ... darn it. ;-)
You're doing a great job here!
Pete
    August 2008
Posted by Astrazoic on Monday, August 31, 2009 8:55 AM
Thanks, gentlemen!
First, here is a closeup of the helium plumbing: http://www.philsmith.us/Mercury62.jpg. I would say that about 75% of the tube routing is accurate. However, due to sloppy preparation, I made a few wrong turns here and there. Using the Mercury Familiarization Manual's excellent line drawing of this area, you can do a great job. Since most of this is covered up, I wasn't too worried about it. My objective was to show a sense of plumbing "busy-ness" in there.
The helium spheres are wooden balls I bought at Michaels in a 4-pack. They're 3/4 of an inch in dia. The straps are styrene, and the balls are firmly secured using superglue.
The lights were added as an afterthought, to help show off interior detail better.
Phil Smith
www.astrazoic.com
    March 2004
Posted by subfixer on Tuesday, September 1, 2009 11:21 PM
Very nice and very busy, just as you intended.
    August 2008
Posted by Astrazoic on Tuesday, September 1, 2009 11:23 PM
So far, so good. I primed the interior hull and did a light test. I am very pleased with the results, as the lights seem to provide that cool, florescent look inside the cabin. I did not fit the pitch, yaw, and roll linkages with the seat - this comes during final assembly.
http://www.philsmith.us/Mercury63.jpg
http://www.philsmith.us/Mercury64.jpg
http://www.philsmith.us/Mercury65.jpg
http://www.philsmith.us/Mercury66.jpg
http://www.philsmith.us/Mercury67.jpg
Here is an external view of the primed interior. Note that I added four pipes (solder) that lead from the left-hand instrument panel to the pitch, yaw, and roll systems. These pipes lead to the push-pull hand loops we all recognize to the left of the astronaut.
http://www.philsmith.us/Mercury68.jpg
http://www.philsmith.us/Mercury69.jpg
Finally, a view in which I test fit the forward bulkhead and hatch.
http://www.philsmith.us/Mercury70.jpg
I am happy that I am finally seeing this thing start to come together. It looks sufficiently busy and cramped, and I haven't started the wire harnesses yet. The beauty of the wire harnesses rests with their ability to hide flaws and gaps. So, next up is painting details, finishing the instrument panel, adding decals and finally wire harnesses.
Phil Smith
www.astrazoic.com
    March 2004
Posted by subfixer on Tuesday, September 1, 2009 11:32 PM
Are the lights included in the kit or were they your own creation?
    August 2008
Posted by Astrazoic on Wednesday, September 2, 2009 9:16 AM
Everything you see in these pictures, with the exception of the black outer hull and portions of the seat, is scratchbuilt. The kit's interior was pretty meager.
The light circuit is simply two white LEDs in series connected to a 9 volt battery.
Phil Smith
www.astrazoic.com
    March 2004
Posted by subfixer on Wednesday, September 2, 2009 3:27 PM
Insane!            I do mean that in the best way.
    February 2005
Posted by rokket on Saturday, September 5, 2009 1:45 AM
whoooooooooooooooooooo...
absolutley fan-freakin'-tabulous. I was pretty blown away by the ctl pnel, but all these sub assemblies and now almost done..beautiful. Huge pat on the back, and waiting for the final!
AMP - Accurate Model Parts Fabric Flags, AM Uboat Goodies & More http://amp.rokket.biz/
    August 2008
Posted by Astrazoic on Thursday, September 10, 2009 8:08 AM
Just a small update tonight. I added a few additional details to the instrument panel, and airbrushed a coat of Future to the astronaut-facing side (no need to worry about the forward facing part). I did add clear covers to all gauges using thin, clear plastic. I started adding stenciling to the various instruments, a process which is taking considerable time. All decals are custom-made, except the white stenciling, which is from my scrounge box.
http://www.philsmith.us/Mercury71.jpg
Phil Smith
www.astrazoic.com
    March 2004
Posted by subfixer on Thursday, September 10, 2009 8:32 AM
The detail is simply amazing. If it wasn't for the picture's background, I would swear that it was the real McCoy. Well done!
    May 2008
Posted by MIflyer on Thursday, September 10, 2009 12:28 PM
Wow, this is fantastic work! Not sure how I missed this so far, but I'm definitely paying attention now!
Is that the kit instrument panel? It looks great... all those perfect little toggle switches!
Kevin
Kevin Johnson    Ypsilanti, Michigan USA
On the bench: 1/72 Fujimi Ki-36 J-BAAR
    September 2005
Posted by Fish-Head Aric on Monday, September 14, 2009 12:41 PM
Wow! That panel is really really great! Of course, being 1/12 scale really lends to allowing for a high level of detail much more readily than something much smaller...
I really can't wait to see all the rest of this when fully assembled.
~Aric Fisher aric_001@hotmail.com
    August 2008
Posted by Astrazoic on Sunday, September 20, 2009 11:06 PM
Thanks, everyone.
I'm basically finished with the interior hull - what remains is more weathering and wire harnesses. Lots of other small details remain - window filters and mirror, coiled cable for flashlight and window pole, assorted small instrument boxes along the forward bulkhead, etc.
The instrument panel is more or less finished, but I need to give it a dull coat and scratch it up a bit. Seat and aft bulkhead painting has commenced, and plans for installing the plethora of wire harnesses will follow...
http://www.philsmith.us/Mercury72.jpg
Phil Smith
www.astrazoic.com
    March 2004
Posted by subfixer on Monday, September 21, 2009 1:00 AM
 I'm really looking forward to seeing the finished model.
    July 2009
Posted by Faith 7 on Monday, September 21, 2009 4:23 PM
Hi,
Really coming along great . i like the weathering that you have done in the interior.
Like all the paint flecks and scratches. Looking forward to see how you wire up all the instruments.
Great work
