The last X-15 flight, in 1/32nd scale…..
    January 2018
Posted by DHanners55 on Monday, February 12, 2024 3:11 PM
I decided to tackle a fairly major cardmodel conversion: Building the original X-15, 66670, out of a model of the X-15A-2, 66671. The cardmodel, in 1/32nd scale, depicts 66670 as it appeared on Flight 1-81-141, flown 24 October 1968 by Bill Dana. It was the 199th and final flight of the X-15 program.
There is a nice card model of the X-15A-2 in 1/32nd scale so that’s what I used as the basis of my model. The model was printed on 170gsm glossy cardstock, and the conversion involved cutting 29 scale inches out of the fuselage and shortening the side tunnels and numerous other alterations. The model also required a lot of scratchbuilding to include the ventral camera installation, wingtip experiment pods, the Phase 2 MIT-Apollo Horizon Experiment and its box behind the dorsal fin, the corrugations and wiring added to the rudder end piece, as well as the third skid (and associated hydraulics) added inside the lower speedbrake well.
A quick example of the type of modification/accurizing involved is the XLR-99 rocket motor. The kit’s motor is made of 15 parts. Of those, I used one part as-is and used another part as a template to cut a new one out of silver paper; all the other kit parts were ditched. The finished XLR-99 is comprised of 65 scratchbuilt pieces.
A friend did the digital repainting of the kit parts to represent 66670 as it appeared on its flight. As markings go, by the autumn of 1968, 66670 looked pretty bland — it carried just the U.S. AIR FORCE legend on both sides of the fuselage (albeit staggered) and “66670” was on the fixed portions of the dorsal fin. There were white photographic stripes on the upper surfaces of the tailplanes.
Modeling the X-15 in card generally presents one big problem: the monochromatic blackness of the vehicle. In real life, the Inconel X alloy the fuselage was made of took on all sorts of different hues and shades after being exposed to the heat of high-speed flight. I wanted to replicate that in some way, and spent weeks experimenting with (and discarding) different techniques.
I finally hit on one that showed promise. I got a silver faux Sharpie from the local pound store and before I cut a kit piece from the paper, I drew a series of parallel lines on it and quickly wiped it with a cotton swab. It created a metallic gunmetal look, and I could blend and randomize the look by the amount of wiping I did. I also taped off different sections or panels to vary the effect.
By its last flight, 66670 was heavily weathered. I replicated that as best I could.
  " alt="" />
  " alt="" />
GAF
    June 2012
Posted by GAF on Monday, February 12, 2024 3:44 PM
Remarkable what you can do in paper!  Nice!
Gary
    January 2018
Posted by DHanners55 on Tuesday, February 13, 2024 12:02 AM
GAF
Gary
Thanks! Modeling is modeling....
    March 2022
Posted by missileman2000 on Thursday, February 15, 2024 10:00 AM
Remind us again of the kit supplier.
Posted by keavdog on Thursday, February 15, 2024 10:17 AM
That is an awesome model.  I just finished the old 1/72 Monogram kit and your card model looks way more detailed!
Thanks,
John
    May 2011
Posted by Real G on Thursday, February 15, 2024 11:51 AM
Spectacular.  Nuff said!
“Ya ya ya, unicorn papoi!”
    January 2021
Posted by JoeSMG on Thursday, February 15, 2024 9:20 PM
Very cool model - and paper ta-boot. Only example that I've seen that looked more realistic was hanging in the Smithsonian.
- Joe the SMG
    January 2018
Posted by DHanners55 on Friday, February 16, 2024 2:34 PM
JoeSMG
Thanks! After 66670's last flight, it was placed in storage. Somewhere along the line, NASA and/or the USAF decided to repaint/restore the markings, and so that's why 66670 looks like it does in the NASM.
    January 2018
Posted by DHanners55 on Friday, February 16, 2024 2:38 PM
missileman2000
Thanks! It is only available legitimately through ecardmodels: https://ecardmodels.com/product/1-32-north-american-x-15-rocket-x-plane-paper-model
    October 2019
Posted by Tanker-Builder on Saturday, February 17, 2024 6:17 AM
Gary;
    Now you see why I-"Tanker-Builder" recommend them to shipbuilders. There's full hull sailing ships and more modern stuff too. Warships, Workships, Smallboats and many many more. They also lend themselves to mods that are way easier to a shipbuilder than Wood or Plastic. Yes! By using a clear spray overcoat you can then paint them any way you want them and weather the heck out of them too.
    The first sailing ship I built was a waterline model. Even the sails look right! By using Bamboo skewers of different sizes I was able to duplicate the masts and steps accurately and fully rig it! Paper can even be shaped like plastic sheet. It just calls on you to think first and then proceed.
      I think the hardest thing I ever did on one was an old German Warship in 1/200. I used various shaded strips of construction paper to plank her deck. Looked like wood too! You can use metal barrels on the guns and P.E. all over the place too!
        I don't think it's still there.I built a large-1/32 version of an L-1011 and hung it in the rec room, of the martinez Ca. V.A. rec center. It had Metallized paper for a lot of it and everyone swore it was plastic. It was so detailed even the engine fans had visible blades.
    March 2022
Posted by missileman2000 on Saturday, February 24, 2024 9:40 AM
DHanners55
missileman2000
Thanks
