sealing pastel dust???
Posted by Anonymous on Sunday, February 8, 2004 4:22 PM
I've read that pastel dust can't be sealed...that it runs or the color changes. Has anyone used acrylic dull coat with an airbrush? Any other suggestions?
THANKS
Posted by Anonymous on Sunday, February 8, 2004 4:58 PM
I've tried sealing pastel dust with dull coat and found that you pretty much loose the effect of the pastels, they just blend in. I don't bother trying anymore. If I find that the pastels have worn off from handling the model too much, I'll just touch them up a bit, especially just before a show.
    January 2003
Posted by shermanfreak on Sunday, February 8, 2004 5:03 PM
Sign - Ditto [#ditto]Sign - Ditto [#ditto]
Posted by Anonymous on Monday, February 9, 2004 8:35 AM
Something I have done with satisfactory results, and this requires a lot of trial and error, is over exagerate the dust and then spray a light dusting of dull or gloss coat. I mainly use Model Master acrylic dull coat straight from the bottle.
As with most tips and techniques, trial and error may be required to satisfactory results.
    September 2003
Posted by maffen on Monday, February 9, 2004 11:29 AM
DON'T seal them, afther applying just don't touch the stuff Big Smile [:D]
    May 2003
Posted by styrene on Monday, February 9, 2004 2:13 PM
Sorry to be the odd man out, but I've never encountered a problem with putting a light coat of flat over applied pastels. Works great..
Gip Winecoff
Posted by Anonymous on Tuesday, February 10, 2004 6:46 PM
I had problems with Dullcote over pastels but learned on a tip to just create a "mist" around the model instead of spraying directly onto the model. Works pretty good.
Posted by BlackWolf3945 on Sunday, February 15, 2004 5:41 PM
You're no longer the odd man out! I've never had trouble either, but I have a light touch and usually spray a bit more dry than most folks. If you spray the stuff on too heavy it's naturally gonna react with the pastel and some of it will disperse.
I suppose it all comes down to technique, like everything else in this hobby...
Fade to Black...
