parts break off easily
Posted by Anonymous on Saturday, February 28, 2004 10:03 AM
I am building an Academy F-16
One of the Rear Wings (?) had a nub that broke off.
I thought 'ok, the pros don't use the alignment pins, why should I?'
Well I am using medium set time CA glue and that wing surface popped off once when I accidentally nudged it. I glued it back on
Now I have these two custom canards that I have attached to the front (ATFI F-16)
They are flush mounted too. I have just used the CA glue again and postponed painting the thing.
I have this Ambroid Pro Weld when I want to squish parts together(that seam fix thing) I have tried that too
Is there some way to make sure these parts don't pop off?
I was thinking of making a notch in the canards. That's easy, since they are custome, but what about the tail surfaces I can't just add a notch to them.
Posted by midnightprowler on Saturday, February 28, 2004 10:07 AM
use a small piece of wire, drill a hole in the part, drill a hole in themodel , glue a piece of wire into the hole in the part, and then glue the part on themodel , inserting the wire into the hole in themodel . that should give it extra strength.
Lee
Hi, I am Lee, I am a plastiholic.
Co. A, 682 Engineers, Ltchfield, MN, 1980-1986
1 Thessalonians 4:13-18 1 Corinthians 15:51-54
Ask me about Speedway Decals
Posted by J-Hulk on Sunday, February 29, 2004 9:55 AM
Lee's got ya covered!
~Brian
Posted by Anonymous on Monday, March 1, 2004 8:40 AM
Well I'll be a son of a .... That is almost the same thing you would do in wood working. (a wood chip that is fitted between to other pieces of wood to make the connection stronger.)
Posted by Anonymous on Tuesday, March 2, 2004 7:22 AM
Yes.. A dowel.
Posted by Anonymous on Tuesday, March 2, 2004 8:36 PM
or a biscuit..
