Tamiya Accent and Alclad
    January 2016
Posted by iSteve on Sunday, September 11, 2016 9:41 PM
Can I use Tamiya Panel Line Accent Color directly over Alclad metallics or do I need to clear coat?
    January 2014
Posted by jelliott523 on Monday, September 12, 2016 9:06 AM
I would probably clear coat just to be safe. I've found that Alclads Aqua Gloss does a nice job of protecting the metallics without altering their color much.
    November 2008
Posted by plasticjunkie on Wednesday, September 14, 2016 9:04 PM
I'm not familiar with that product but if it's solvent based, then seal the Alclad with Aqua gloss, otherwise you may run the risk of the Alclad bubbling or cracking.
 GIFMaker.org_jy_Ayj_O
Posted by Bish on Thursday, September 15, 2016 1:07 AM
I think i am right in saying that tamiya accent is an enamel wash, so yes, i would protect the Alclad.
    January 2016
Posted by iSteve on Thursday, September 15, 2016 1:52 PM
Tried it in a few small spots with no apparent damage to the Alclad. You're right gentlemen, it is an enamel but I'm only doing a couple of small areas and with the results so far, it should be fine.
    November 2008
Posted by plasticjunkie on Thursday, September 15, 2016 4:16 PM
I guess the Alclad is purty tolerant. Good to know.
Posted by Don Stauffer on Friday, September 16, 2016 9:25 AM
The only thing I have had trouble with using over Alclad is CA accelerator.  That does make a mess of it.  If you have to glue on a piece in an area with Alclad finish, just glue it and let it set- do not use accelerator.
