Gluing antenna
    December 2014
Gluing antenna
Posted by rsm.gbg on Thursday, December 15, 2016 7:38 PM
Hi,
Im trying to glue the antenna to my Revell, Sea Lynx MK88A 1/32.
I have tried 3 types of Super glue the ordinary revell plastic cement and a couple of "household" glues.
Nothing really works, they stick there but blow on them and they will get loose.
I'm using a monofilament fishing line 0.2mm gluing on the painted antenna "holders"
What are you guys using?
- Roland
    July 2004
Posted by stikpusher on Thursday, December 15, 2016 9:14 PM
I've never used monofiliment for an antenna, but I imagine that it is a pretty slick surface for the CA to adhere onto. I would suggest perhaps a gel type CA glue or some very fine gauge wire instead of the fishing line. Or if you can get ahold of it, EZ Line. I have read and heard many rave reviews of that stuff.
U is for URANIUM... BOMBS!
N is for NO SURVIVORS...
       - Plankton
LSM
Posted by Don Stauffer on Friday, December 16, 2016 7:05 AM
I try to tie the thread to the mast.  I know, tying knots with monofilament is a ***!  Every time I do it I swear I will never do it again.  I use gel CA to fix it to the mast- I use that even in the rare case I do not tie it to the mast.  Tieing it to the mast(s) allows me to tighten the monofilament with a heat source.
    December 2014
Posted by rsm.gbg on Saturday, December 17, 2016 4:17 AM
yea, slick was the problem.
I just roughed up the line with some 600 grit paper and now it's just perfect.
And the paint is much better as well.
- Roland
