Liquid mask
    August 2012
Liquid mask
Posted by JMorgan on Wednesday, June 28, 2017 5:05 PM
Is this stuff designed to be used on a flat or glossy surface? I have the darndest time getting it to peel off of flats.
    April 2009
Posted by Cadet Chuck on Wednesday, June 28, 2017 8:29 PM
I don't know, but I have never had any luck getting it off anything, including clean clear plastic canopies.  Due to the disasters I have had, I have quit using it for anything.  It would seem like a good idea, but I have tried several brands and have had no luck with it.
    December 2013
Posted by route62 on Wednesday, June 28, 2017 9:28 PM
I have used micro mask blue liquid mask on both gloss and flat surfaces with no issues.  Simple rubbing with finger or soft eraser/blue tack rubs the mask right off.
    August 2012
Posted by JMorgan on Thursday, June 29, 2017 2:20 AM
Micro mask is what I am using too. Does it get old, because mine is not doing well? Also, how thick must it be applied?
Posted by Bish on Thursday, June 29, 2017 6:32 AM
I've had my bottle of micro mask for a long time. I only use it on canopies, so can't comment on flat or gloss paint. But i do always apply to coats and lay it on ba bit thick.
    March 2013
Posted by patrick206 on Thursday, June 29, 2017 1:39 PM
I only use Micro Mask on clear bits, or bare plastic that I mask to temporarily keep clear of paint. But I do have a couple that are VERY old and still work well.
It's water soluble, so maybe you could just wash it off with wet cotton buds, (Q-tips,) after the paint has set up well. Once you have an edge lifted, you could perhaps just keep working the water under the layer. The paint on top of the mask, would prevent water from dissolving it from the top side.
Patrick
    August 2013
Posted by Jay Jay on Thursday, June 29, 2017 2:02 PM
Interesting thread . i can see the advantagous use of liquid mask and wondered if there was a better product out there. I used "The Deailer" liquid mask and it stained my clear parts purple. Luckily i only used it on an interior bulkhead window and some small port hole windows on my B-26.
    January 2017
Posted by ecotec83 on Thursday, June 29, 2017 9:45 PM
Honestly I've had no luck with liquid mask, alway causes me more headaches than it solves. Since flat paints are more grainy than gloss it is possible that the mask sinks into these imprefections making it harder to remove.  Lately I have been using silly putty to mask and protect from overspray as well as tamiya tape.
