- Member since
June 2017
Tamiyas extra thin cement for fuselage
Posted by Mars
on Sunday, August 20, 2017 2:26 PM
I have been using Tamiya extra thin cement for putting small parts in place then adding a bit of extra thin cement. It's a lot cleaner application than regular model cement. How strong is the extra thin bond? Can I put an airplane fuselage together with rubber bands, adjust all contact areas to the right position and then apply the extra thin cement? Would that be as strong as Testors model cement in the same place? It could save me a lot of filling and sanding.
