Silly putty
    August 2012
Silly putty
Posted by JMorgan on Sunday, August 27, 2017 12:43 AM
Make sure to double-check your masking right before you shoot your airbrush as Silly Putty creeps where it is unwanted! I'd use a razor blade to get the best edge.
    December 2006
Posted by Fly-n-hi on Sunday, August 27, 2017 2:11 AM
Not sure what you mean...I've used Silly Putty several times to mask camo on 1/48 jets and I've never had any problems.
When you say "use a razor blade" what exactly do you mean?  I wouldn't ever use a razor to cut the putty once its on the model...if that's what you meant.
    August 2012
Posted by JMorgan on Sunday, August 27, 2017 3:46 AM
Well, when I mask, the Putty moves back over what I am trying to paint. I use a razor blade to burnish the Putty below raised details I am trying to paint.
    March 2014
Posted by BarrettDuke on Sunday, August 27, 2017 5:47 AM
JP, That's interesting. I've never seen Silly Putty move from where I put it, but I don't use it if I need a precise line. I just pull out the Tamiya masking tape for those. I'd be nervous about using a razor blade next to the model for fear of scratching the plastic. Barrett
Posted by gregbale on Sunday, August 27, 2017 6:04 AM
As a PITA/KIAOG (pain-in-the-***/know-it-all-old-guy) I've learned---the hard way---to spot-check all my masking, of any type, before pulling that AB trigger. Saves a lot of muttering under the breath and head-shaking---which at my age, might shake something loose....
But seriously, even the best-behaved tape or putty can lift or pull back at that inconvenient spot. A quick once-over---a 'pre-flight check,' if you will---can prevent a lot of frustration.
Greg
George Lewis:
    July 2013
Posted by modelmaker66 on Monday, August 28, 2017 1:21 AM
Great advice Greg! I know I could have used it many times!
