how to remove this part?
    April 2019
Posted by united2019 on Friday, April 19, 2019 12:56 PM
I put a wrong AIM-9 rail thanks to hasegawa lazy instruction. how can I unglue it? it is glued by plastic cement. pic below. thanks
https://drive.google.com/open?id=1KbevIXP7Vg4p2oEVfVE5A1XBFivYN_Es
Posted by gregbale on Friday, April 19, 2019 1:13 PM
My personal approach would be to put it in the freezer for about two hours...helps make the glue joint brittle...then just snap it off.
Whatever method you use, there's likely to be some filling/sanding/restoration needed.
Greg
George Lewis:
    April 2019
Posted by united2019 on Friday, April 19, 2019 2:15 PM
will other parts get loose after freezer?
Posted by gregbale on Friday, April 19, 2019 2:48 PM
united2019
No, nothing really gets 'loose.' The cold just tends to make the joint areas a little more brittle, so when you stress the joint...hopefully just the part you want to remove...it should give way more easily. (How easily will depend to a large degree on how solid the bond was to begin with. The technique works well with cement-type adhesives...less-well with 'bonding' types like Weld-On, Tenax and such.)
Once the whole thing warms up again to room temperature, the 'brittle' factor should essentially disappear.
Greg
George Lewis:
    August 2014
Posted by goldhammer on Friday, April 19, 2019 3:07 PM
Might try wicking in a thin liquid cement, like Tamiya extra thin, a couple of applications over a few minute period and then wiggle it loose as it resoftens the joint.
Have done that a couple of times with minimal damage to the parts.
    September 2006
Posted by the Baron on Friday, April 19, 2019 5:31 PM
What about using a new Nr 11 blade to score along the seam between the rail and the pylon, and removing it that way?
    September 2012
Posted by GMorrison on Friday, April 19, 2019 6:02 PM
That's what I would do, and be prepared to lose either the rail or the pylon.
    November 2008
Posted by plasticjunkie on Friday, April 19, 2019 7:56 PM
I would use GH's method to weaken the join. If that doesn't work then using the backside of a #11 blade to gently score the join line will work too.
 GIFMaker.org_jy_Ayj_O
    December 2015
Posted by templar1099 on Saturday, April 20, 2019 6:13 AM
goldhammer
I've had success with this method only using nail polish instead of cement.
"le plaisir delicieux et toujours nouveau d'une occupation inutile"
    June 2014
Posted by Tanker - Builder on Sunday, April 21, 2019 9:48 AM
Hi;
      I use the freezer method along with what " G " suggested . What I do though, is run a NEW #11 blade backwards GENTLY ! along the join line .The new blade will find a gap if there are any .
 The only difficulty is if tube glue was used .Then use a P.E. Microsaw! T.B.
Posted by Don Stauffer on Monday, April 22, 2019 8:44 AM
One advantage of CA is that a debonder is available for it. The debonder works well as long as you do not use too much excess.  A little goes a long way.  Too much and it will soften the plastic, though.
    May 2013
Posted by Greg on Monday, April 22, 2019 7:15 PM
The suspense is killing me. Did you get the part separated?
    January 2013
Posted by BlackSheepTwoOneFour on Monday, April 22, 2019 9:25 PM
Don Stauffer
He didn't specify he used CA glue.....
    April 2019
Posted by united2019 on Tuesday, April 23, 2019 3:35 PM
thanks for all your reply. looks like none of the solution is easy, so I just gave up. I already spent 4 weeks on the model, and do not want to take any risk.
