Looking for Panel lining advice.
I generally paint my models with Vallejo Acrylics and then put an Acrylic clear gloss coat on top for Decals.
What kind of paint should I use to do a pin wash with? Oil or Enamel? I keep hearing your pinwash should be a different type of paint from the base and gloss coat. I just tried experimenting with using an oil wash but the turpentine I thinned the oils at through the clear gloss on my test piece like acid.
I read somewhere that enamels mixed with white spirit is a good wash to put over an acrylic clear coat, but I was under the impression that any enamel solvent of any kind would eat through acrylic pretty quickly too.
Thanks all in advance.
