Gluing upper and lower body parts
    January 2020
Posted by wpwar11 on Monday, April 19, 2021 3:05 PM
I currently on an old AMT Ertle indycar kit.  I'm at the point where I need to glue the upper front body to the lower floor assembly.  Both parts are painted.  I tried this with super glue already and made quit a mess.  I was able to get the parts separated and started sanding the mating surfaces free of glue and paint.  What's the best glue or technique for this?  If it helps, there is only one pin and hole on the very front nose piece.   The rest of the join is just surface to surface.  If the parts werent painted this would be a job for Tamiya extra thin but that won't work on painted pieces.
Thanks.
Posted by keavdog on Monday, April 19, 2021 7:09 PM
Which kit is it?
Thanks,
John
    January 2020
Posted by wpwar11 on Monday, April 19, 2021 7:35 PM
It's the March 88C Kraco car driven by Michael Andretti.  Kit 6713.
    August 2014
Posted by goldhammer on Monday, April 19, 2021 9:59 PM
If the mating surfaces are clean, brush on a couple of applications of extra thin on both halves and then locate and secure.  If you're careful with glue, shouldn't mess up the paint.
Another option might be to glue a strip of styrene on the inside if it has a relatively flat seam area, to use as a glue block.  Apply glue to inside of other piece and assemble.
If you have access to the inside, may be able to hold or tape together and wick thin on the inside of the parts.
Posted by keavdog on Monday, April 19, 2021 10:09 PM
What goldhammer said.  Maybe try both, Tamiya thin on both surfaces and if you have a coulple tabs glued on that will help with alignment.  Looking at the instructions I'd say the engine cover shouldn't be glued so you can remove to look at the engine.
Thanks,
John
    September 2012
Posted by GMorrison on Monday, April 19, 2021 10:56 PM
wpwar11
I think you answered your own question.
Beautifully engineered kit, needs all of your best thinking to make it the best you can do.
Bill
Posted by Tojo72 on Tuesday, April 20, 2021 6:25 AM
When I read the subject line,I was really wondering what we were talking about here.Maybe what to do when you accidently glue your fingers to your leg,or worse
Really I thought you were talking figures
Posted by Don Stauffer on Tuesday, April 20, 2021 9:08 AM
If there are visible seams in an assembly, I do not paint until seam is glued, sanded/filed, and filled.  There are always ways to fill big cavities and openings.
    September 2012
Posted by GMorrison on Tuesday, April 20, 2021 9:50 AM
One comment about adding tabs.
Sometimes the two parts are not molded in the same thickness, where the outside of the assembly is to be smooth across the joint but the inside is not.
Be sure to check this before adding tabs.
Bill
    January 2020
Posted by wpwar11 on Tuesday, April 20, 2021 11:28 AM
Thanks all for help.  If I apply the extra thin to both halves of the piece how long until it starts to set?  I might try the tabs too.  That's a good idea.
Keavdog,
Nice of you to to take the time and look at the instructions.  I spent time detailing the engine so the cover will not be glued.
    January 2020
Posted by wpwar11 on Tuesday, April 20, 2021 11:31 AM
Tojo72
LOL. I could have done a better job with the description.  My fingers aren't glued to my knees.  It does read like a figures question.
    August 2014
Posted by goldhammer on Tuesday, April 20, 2021 12:31 PM
Couple coats of thin should give you 15-20 seconds.  Orange top would give you more time, if you have it, but I wouldn't get a bottle just for that.
    January 2020
Posted by wpwar11 on Tuesday, April 20, 2021 12:36 PM
Just so happens I do have the orange top.
    August 2013
Posted by Straycat1911 on Wednesday, April 21, 2021 8:25 AM
Tojo72
You and me both, Tojo. :D
