When I buy an old kit from eBay
    April 2023
Posted by John3M on Wednesday, March 6, 2024 6:28 AM
I will sometimes see an older kit I would like to get from ebay and build it. However, I will find to my dismay the plastic part has a slight warp. Is there a method to right the part back into shape?
    February 2021
Posted by MJY65 on Wednesday, March 6, 2024 7:46 AM
Lots of variables, so "it depends".
Slight warp on a long flat piece can sometimes be straightened just be hand.   Worse bend on a shorter piece sometimes benefits from a bit of heat (hair dryer on low, not fire).
If it is a bigger part and only a small area is distorted, I often assemble as it should be and deal with the distortion with sanding/filler depending on if the defect is a negative or positive step.
    April 2020
Posted by Eaglecash867 on Wednesday, March 6, 2024 8:50 AM
I have a Steinel temperature controlled heat gun that I can set for 210 degrees and straighten out pretty much any warped model part.
"You can have my illegal fireworks when you pry them from my cold, dead fingers...which are...over there somewhere."
    June 2014
Posted by BrandonK on Wednesday, March 6, 2024 9:23 AM
Yes, the gentle application of low heat will fix many warpage problems. Take your time and work carefully and you can correct some pretty bad stuff.
On the bench:
A lot !! And I mean A LOT!!
                         14 / 5 / 2
                              Tongue Tied
fox
    January 2007
Posted by fox on Wednesday, March 6, 2024 6:13 PM
I've saved a few warped pieces by setting in a bowl of hot water. After a minute or two I put them on the bench and depending on the size I clamp them to shape or weigh them down with various weights until the part cools.
Hope that this helps.
Stay safe.
Jim Captain
 Main WIP:
    March 2015
Posted by JohnnyK on Thursday, March 7, 2024 3:48 PM
If an airplane wing is warped, I use this trick.
I apply glue to the upper and lower surfaces of the wing and clamp an Architect's Scale to the wing.  The scale is super stiff and you can buy it at a craft store. After the glue cures, the wing is straight.
    March 2012
Posted by mustang1989 on Friday, March 8, 2024 5:43 AM
JohnnyK
I like that idea Johnny. Yes
 Forum | Modelers Social Club Forum (proboards.com)
    March 2015
Posted by JohnnyK on Saturday, March 9, 2024 2:10 PM
It works all the time.
