best way to venelate............
Posted by Anonymous on Tuesday, April 15, 2003 7:21 PM
i have an enclosed room for my model room whats the best way to venelate it?
Posted by Anonymous on Tuesday, April 15, 2003 8:33 PM
open a window, open a door, dont build
    January 2003
Posted by shermanfreak on Tuesday, April 15, 2003 8:58 PM
Is your modelling room located on an outside wall or near to a room that has a window?
Posted by Anonymous on Wednesday, April 16, 2003 3:58 PM
unnamed player i said it is an ENCLOSED room, comon, dont build? dont be a dumbass im asking so i can build!!!!!!!Tongue [:P] i have no windowws in my basement.
Posted by kaleu on Wednesday, April 16, 2003 4:45 PM
I work in the basement and have a couple of fans blowing air around the room.
Erik "Don't fruit the beer." Newest model buys: More than I care to think about. It's time for a support group.
Posted by Anonymous on Wednesday, April 16, 2003 7:25 PM
Move to a different room.
M.
    January 2003
Posted by shermanfreak on Wednesday, April 16, 2003 8:36 PM
You can always use a fan to ventilate the room but really all you're doing is spreading the joy throughout the rest of the basement. Can you install a dryer vent in the wall of the room leading outside?
    January 2003
Posted by Keyworth on Friday, April 18, 2003 6:25 PM
Paint at someone elses house! Seriously, open a window, use a floor fan to redirect the fumes, use a paint booth with an outsite connection; anything that keeps you out ot he ER from solvent toxicity. - Ed
"There's no problem that can't be solved with a suitable application of high explosives"
Posted by Anonymous on Saturday, April 19, 2003 12:09 AM
If your dryer is in the basement you could get a range hood that has a 4" (same size as dryer) vent connection and tee it into the dryer vent. you would NEED dampers to prevent hot air entering your modeling room or paint entering the dryer.
Belay that! NOT one of my brighter ideas! Solvent/paint fumes could enter the dryer and cause an explosion or serious fire.
But you stillcould stilluse a range hood with a 4" vent connection. Just find a different wat to get it outside.
Posted by Wingman_kz on Saturday, April 19, 2003 12:42 AM
Well, you sound like the perfect candidate for one of those water filter buckets. Of course, first you'd have to build a spray booth of some sort and then run the hose to the water filter. I don't remember where the thread is but there is a topic discussing this somewhere either in *Techniques* or *General Discussion*. Look for threads concerning paint booths or exhaust fans. If I run across it I'll post a link.
    January 2003
Posted by Keyworth on Saturday, April 19, 2003 7:55 AM
Does your modelling room have a window? You might try replaceing one pane with plexiglass. You can affix a dryer end vent on the plexiglass, add the plexiglass back into the frame and then hook up whatever fan source you're using to that. One of my modelling buddies has two setups like that and it works just fine. He has one window with two outside end vents in place joined with a t-connector; one draws outside air in, the other vents to the outside. Materials aren't expensive, and it should only take a short time to do. -Ed
Posted by Anonymous on Saturday, April 19, 2003 12:07 PM
HE SAID ENCLOSED!i!Big Smile [:D]Big Smile [:D]Cool [8D]
    January 2003
Posted by Keyworth on Saturday, April 19, 2003 8:47 PM
Oops, my bad. But IF you had a window, all that other stuff would work {:)}
Posted by Anonymous on Sunday, April 20, 2003 8:42 PM
well enamal paint fumes do smell good...
Posted by Anonymous on Tuesday, April 22, 2003 8:41 AM
I'm with unnamed player... gotta move to a ventilated room, bro. Either that or fry your brain on paint fumes. Not worth it, kemosabe.
Posted by Anonymous on Tuesday, April 22, 2003 5:58 PM
You could try this...
http://www.armorama.com/modules.php?op=modload&name=Sections&file=index&req=viewarticle&artid=57
I am in the same boat you are. I am in the garage and it's gets too cold and rainy to do much outside painting (I live in Seattle) so this looks like a pretty good alternative. I am in the process of building up one myself. We'll see how it goes I guess.
Posted by Anonymous on Tuesday, April 22, 2003 8:12 PM
Maybe if you use the previous hood idea but use a really long hose and run it up the stairs and out a door or window? Just coil it up when not in use.
Posted by Anonymous on Tuesday, April 22, 2003 11:47 PM
I think that a bathroom vent would work better than a range hood. A bathroom vent is already pretty powerful (more than a range hood). So that should be enough for you. You might have to put 2 in, but I think that would be the best way to go.
adws
Posted by Anonymous on Wednesday, April 23, 2003 2:47 AM
QUOTE: i have an enclosed room for my model room whats the best way to venelate it?
QUOTE: i have no windowws in my basement.
The problem that we have to address is NOT what type of fan to use but how to get the fumes out of an ENCLOSED, WINDOWLESS BASEMENT! There is a possibility that you could use the stand pipe OR a dryer vent OR a tube up the stairs. Does any one live near Juniormodeler? I don't know if this is his(her) house an apartment or his(her) parents house. If I knew the layout of the home I might be able to give a better suggestion.Maybe if one of us could go there we could help.
