Need Tip In Sprue Cutting
Posted by Anonymous on Thursday, August 12, 2004 10:42 AM
Hi to all, I need tips from you all as to how do you cut clear plastic parts from its sprues. I have experiences that when I cut canopy parts from its sprue, the canopy was been slightly damaged. Any tips as to how to detach the sprue without affecting the canopy? Thanks in advance.
Posted by Anonymous on Thursday, August 12, 2004 10:45 AM
Well what ya wanna do is snip it with a large piece sprue on then snip it down in pieces. when you get close tot he clear part sand the rest.
    July 2003
Posted by Foster7155 on Thursday, August 12, 2004 11:04 AM
Exactly, woodbeck3.
With smaller parts, thin parts, or clear parts, I always cut through the sprue between 1/8" and 1/4" (sometimes more) away from the part. Then, with the part seperated and all the tension off the connections, you can nibble away the remaining sprue at each connection point. Sometimes I will leave 1/16" of the connector on the part and sand the rest away from that point.
Enjoy your modeling...
Robert Foster
Pensacola Modeleers
Posted by dubix88 on Thursday, August 12, 2004 4:27 PM
HEY,
I have these wire cutter things and i cut the sprue close to the peice but not too close an take my dremel or sand paper or even my hobby knife and take care of the rest.
Randy
THATS MY VOTE "If a woman has to choose between catching a fly ball and saving infant's life, she will choose to save the infant's life without even considering if there is a man on base." -Dave Barry In the words of the great Larry the Cable Guy, "GIT-R-DONE!!!"
Posted by Anonymous on Friday, August 13, 2004 8:15 AM
Thanks for the tips guys.
    September 2003
Posted by glweeks on Saturday, August 14, 2004 2:21 AM
Big toe nail cutters will work too. I use the big ones and smaller ones, then sand when I get close to the part.
G.L.
Seimper Fi "65"
    January 2004
Posted by MusicCity on Saturday, August 14, 2004 6:32 AM
Also, if you have room when cutting the sprue, lightly hold the spot where the sprue joins the part between your fingers. That lets your fingers absorb some of the shock when the sprue cuts and prevents it from breaking off. Clear plastic is very brittle, for some reason, and you have to exercise a little more care.
Posted by Anonymous on Wednesday, August 18, 2004 4:10 PM
Zip Zip Zip, cut cut cut, and a couple of tra lahlah's, thats the very sound of it when you use your dremel as a saw.......Clown [:o)]
Posted by sh00ter on Sunday, September 19, 2004 5:42 PM
A couple passes with a jeweler's saw does the trick for me. I'm careful not to cut too close to the piece tho and hit it once or twice with a manicurists sanding stick.
Dennis Cool [8D]
"where plastic can be a four-letter word..."
Posted by Anonymous on Friday, September 24, 2004 11:31 AM
dunking in future will help prevent splintering.
out of curiosity, does anyone know why clear plastic is brittle, and colored sprue isnt ? the plastic is actually clear to start with, they only add color pellets later in the plastic-making process. but why would the clear be more brittle ?
    July 2004
Posted by tho9900 on Friday, September 24, 2004 12:31 PM
it's what they make the plastic out of that makes it different. Styrene is the colored parts... if I remember right (and probably don't so don' t be surprised to see a correction to this later) clear pieces are made out of butyrate or Vivak which is a co-polyesther.
Posted by Anonymous on Saturday, September 25, 2004 5:47 AM
hmm, interesting, i think you are probably right, cos i read about the plastic manufacturing from a magazine about industrial plastic, so its probably different. now i know !
