i wanna ask!!!
i wanna ask!!!
Posted by Anonymous on Sunday, September 26, 2004 7:04 AM
Hey all,
can any1 give some tips on how to get a good on the Motor,inside the car? and what is best way to color in the tail lights???
Posted by Anonymous on Sunday, September 26, 2004 7:23 AM
i presume you want tips on detailign the engine and painting tailights. to answer the first question, all i can say is just buy a snall brush and be careful Tongue [:P] to answer your second question, if you are painting clear plastic tailights red, id suggest just picking up a bottle of clear paint from any paint company, and then before gluing the tailight on to the area, back the tailight with household foil. attach the foil to the tailight with white glue, and then attach the foil and tailight tot he car with white glue. if white glue isnt strong enough, use a *very* sparing amount of CA (superglue) all you need is less than a drop. a tiny little smidgen is enough. i cant emphasize enough how little you need.
anyway, have fun and tell us how it goes
Posted by Anonymous on Sunday, September 26, 2004 8:25 AM
any1 here use the Fine Point Permanent Markers for detailing & for the tail lights??
Posted by Anonymous on Sunday, September 26, 2004 8:49 AM
its me again, i use tamiya paint markers to do certain fiddly bits like doors of USN aircraft and the doors of my enzo. if you are using normal stationary markers, they may not have thick enough paint, so do check that.
    July 2004
Posted by tho9900 on Sunday, September 26, 2004 8:31 PM
well to do the taillights I would be careful which marker you use, some might run or not dry on the plastic (had that one happen once) others might be a little harsh and you may lose a little of the detail on the lens bevel...
Posted by Anonymous on Monday, September 27, 2004 3:50 AM
i'll use the same post then making a new one, i wanna ask what do u all use to do the Interior detailing inside the car to make it look like its real? and are they any paint pen markers like u can get to do the inside of the car then using a paint brush
    August 2004
Posted by Ernie on Tuesday, October 19, 2004 9:01 AM
Kalambach publishing has two great books on how to detail cars. one is race cars the other is for regular cars and trucks. you should be able to find them at your hobby store or co to their web site finescale.com. and order them from there.
Posted by Anonymous on Monday, December 20, 2004 11:20 PM
i have a 1/72 airfix dh2 beaver model kit that was given to me last christmas, but it has no prop. i read in fsm that a clear plastic dis could be made to simulate a rotating
prop. the question i have is how does some one decide how big the disk should be?
so that it looks good?
Posted by Anonymous on Monday, December 20, 2004 11:33 PM
Talilaight and indicator lenses are best painted from the inside with clear colours(they look more realistic that way).
I don't attach the silver foil to the clear parts but rather to the car itself.
Personally, I stay away from markers as far as possilble. IMO, not enough control and too expensive, said that I do use the Gunze water based marker for panel lines.
HTH.
Posted by ajlafleche on Tuesday, December 21, 2004 12:29 PM
Tail and marker lights are the only place I use Tamiya paints. Their clear amber, red, and green (aircraft applications) work great for this. As with the post above, apply silver to the car/lens housing. Use BareMetal foil if at all possible. Apply clear amber or red as apppropriate to the inside of the lens. Attach with white glue after painting the body work and getting the level of gloss you like. You can blend them in with some carnuba wax.
Detailing the engine compartment can be a gret deal of fun. Find some references for the prototype in magazines, books or online. There are scale ignition wires in a variety of colors and prewired distributor caps and braided cable and rubber hoses. There are also many photo etched and turned aluminum accessories, too.
Posted by Anonymous on Thursday, December 30, 2004 10:07 PM
I can only answer the tail light question! MM makes Both Stoplight Red and Turnsignal amber both are exact copies of the color used in tailight and trun signal lenses. As for an alternative go to any arts and crafts store and by one of those PAINT IT YOURSELF plastic stained glass window kits, the colors used in them as Perfect for models and come in RED, GREEN, YELLOW, AMBER, BLUE, WHITE, BROWN. great for tinting windows or shading windshields. great for Blue tint headlights and for airplane formation and navigation lights as well as tinted overhead windows and on armour for the vision blocks.
