Canopy Future Question
    June 2004
Posted by nicevillescott on Monday, September 27, 2004 9:26 AM
Do you dip the canopy in Future before or after you paint it?
    August 2003
Posted by tweety1 on Monday, September 27, 2004 9:31 AM
Before you paint.
Wink [;)]
Just dip, and set on some paper towel for a couple of minutes to wick away any excess Future, then move it to somewhere where it can be covered to dry overnight.
--Sean-- If you are driving at the speed of light and you turn on the headlights, what happens???
    June 2004
Posted by nicevillescott on Monday, September 27, 2004 9:42 AM
Thanks Tweety. Should I be concerned with masking tape pulling any of the Future off?
    December 2003
Posted by gharlane on Monday, September 27, 2004 10:35 AM
let it dry a minimum of 24 hours (preferably 48 hours) and you won't have any problem from masking tape pulling off the Future coat
hope this helps
Posted by genj53john on Monday, September 27, 2004 7:41 PM
The Future needs to cure at least 48 hours and even longer is better. I suggest one of the first things you do is to dip in Future and than set it aside in a dust free environment. Now start building your model. By the time you get back to painting the canopy the Future should be fully cured and provide a smooth hard surface. I will usually repeat the Future process after painting because no matter how careful I am I usually end up putting a hairline scratch somewhere on the canopy. The Future does a good job of making these scratches (assuming the're minor) disappear.
John
John
Posted by pingtang on Tuesday, September 28, 2004 10:28 PM
I tried dipping one in future after I painted it. It ruined my nicely painted frame. I usually dip the canopy as soon as I start the build and ,buy the time I'm ready to paint it, it has completely cured and is safe for masking.
-Daniel
