QUOTE: i wanna ask something ask but i didnt know where to put this so..i'll ask here, i got a '85 Camaro Z-28 but its molded in red + the parts and the body dont look good it got lines like in the body i wanna know how i can fixed the body and can i paint diff colors over the red if its molded in red whatever? sorry if this needed to be in a other part of the forum
If the lines are panel lines, such as around the doors, hood, and trunk, it will look more realistic if they are left. Take a look at a real car and you can see that the lines around the doors are always visible and they are always black (or dark gray) because they are in shadow.
You can remove the lines, but unless you take your time and do it right the model will look worse. If they are raised lines sand them off. Use a small wooden block and put your sandpaper over it. That will help keep the sanding even. If they are sunken lines, here is a link to a good article: http://www.swannysmodels.com/Seams.html The article pertains to repairing seams on aircraft, but the idea is the same.
As to painting the body, sure you can. I never leave anything the same color as it came out of the box. You will need to paint it before assembly or spend a lot of time masking areas you don't want to get painted. I'd also recommend that you use either a spray can or airbrush. That will look much better than if you used a brush.
