Sprue Glue?
Sprue Glue?
Posted by Anonymous on Saturday, October 2, 2004 8:54 AM
So I have streched my Sprue to form a wire for the antena on my 1/24 scale Hurricane...
But how do I glue this? I've tried superglue but when I try to put the smallest amount of tention on it so that it is straight it pulls off.
Any tips?
Thanks
Posted by rjkplasticmod on Saturday, October 2, 2004 9:30 AM
First, welcome to the Forum Sign - Welcome [#welcome]. The procedure I use is to first glue the antenna to the radio mast or forward most anchor point. You can use CA or white glue. After that has set, glue it to the rear anchor point, but note that the antenna should be slightly longer than needed so that no tension is on the wire. There will be a slight sag at this point. After the glue has completely set, bring a heat source near the wire. It will sag a litte when heated. Immediately remove the heat source when you see the sag & the antenna will snap up nice & taught. For a heat source, I use a small portable hair dry blower, but you could also use a freshly extinguished match, a lit cigarette, a screw driver blade heated over a candle, etc. Takes a little practice to avoid melting the antenna, but is really pretty easy to do.
Regards, Rick
Posted by Anonymous on Saturday, October 2, 2004 10:01 AM
superglue and accelerator. the accelerator sets the glue in 1 second or less. then use rick's method. let us see some pics, wont ya ?
Posted by Anonymous on Saturday, October 2, 2004 10:45 AM
DAMN!
I tried your technique, (thank you for your reply BTW) and it worked. but then I got greedy and tried it again, so it would be even better! and I melted it. Classic!
so I'm making a new wire.. and this time I will resiste the temptation to over do it.
how do i post pics? (sorry if that's off topic)
Thanks again for you help
B
    August 2003
Posted by tweety1 on Saturday, October 2, 2004 11:19 AM
I use my wifes hair!
She doesn't know it, but all my antenna wires are thanks to her and her hair brush.
As for pics, first you need a website to host them for you.
I use photobucket.com
But there are others.
--Sean-- If you are driving at the speed of light and you turn on the headlights, what happens???
Posted by Anonymous on Saturday, October 2, 2004 11:35 AM
Thanks
Here are some pics of the Hurricane.
Not the best camera so the pics aren't the best. this is the first time I've posted pics I hope this works (insert generic "old dog new tricks" joke here)
enjoy
B
http://photobucket.com/albums/v478/Ted_Nugent/
    July 2004
Posted by tho9900 on Sunday, October 3, 2004 7:46 AM
We can't see them, if you go into account options, which is right above the add pictures dialog when you first log into photobucket, then right underneath the URL to your page there is a line that says "make public" if you check yes we can all see your album...
Posted by Anonymous on Sunday, October 3, 2004 8:05 AM
Done.
Thanks
Posted by rjkplasticmod on Sunday, October 3, 2004 9:33 AM
OK, now we can see it, and certainly worth the look. Excellent build. Thanks for posting.
Regards, Rick
