- Member since
Posted by Holley
on Monday, June 9, 2003 6:49 PM
Rob,
Hypodermic needles make excellent gun barrels. Your local pharmacy or if you have a nurse friend can help you locate some. Under no circunstances, ever use a used needle...you may catch the death of you!!! Either cut them off with a cut-off wheel in a dremel, or snip them with cutters and file the ends down. I have had really good results using several different guage needles.
Holley
When all else fails, read the instructions!
