i wanna ask something about the wire's + the distributor that u do on model cars
Posted by Anonymous on Saturday, March 19, 2005 11:02 PM
i wanna know do u use the distributor that comes the kit or u make your own distributor? and can u all give me some sites step by step on it too
    March 2004
Posted by bstrump on Sunday, March 20, 2005 12:13 AM
I always used the kit supplied distributor ang using a #72 or#76 drill bit in a pin vise, drilled out the holes for the wires. Then I used aftermarket scale spark plug wire to dress it up. I haven't done cars in a while so I forget where I got the stuff from but the name Model Empire comes to mind. For additional info you might try the Scale Auto forum as I'm afraid I'm not too deep into cars so I can't be of much more help. scaleautomag.com/sca/community/forum
Posted by Anonymous on Sunday, March 20, 2005 9:10 AM
Detail Master makes turned aluminum distributors and has the wire you will need. It comes in a few colors or can be painted. If you are building something that is basically stock I would definately use the kit distributor drilled out, if its something thats is supposed to have a modified engine the turned aluminum one looks like an aftermarket MSD unit that may be more accurate. My local Hobbytown carries all of these items so they are not hard to find.
Posted by Anonymous on Sunday, March 20, 2005 10:00 AM
thx for your reply's
