Washes - Airbrush or brush
Posted by Anonymous on Friday, April 1, 2005 4:09 AM
For armour where washes are applied to the whole model, would airbrushing or using a paint brush be more effective?
What color oils would you guys recommend for a base cost of olive drab that has darkened due to the gloss coat applied over it.
Thanks.Smile [:)]
Posted by Anonymous on Friday, April 1, 2005 4:33 AM
Frankly, I wouldn't know how to apply a wash - the way I understand this - with an airbrush.
A wash is made with heavily thinned paint, preferably applied on a smooth surface (future or gloss paint), with a brush. The paint then flows into gaps and along engravings.
Using an airbrush would (probably) lead to a thin coat all over the model, not accentuating any detail, as the wash needs some 'volume' to make it flow along the detailed surface.
Usually black, or a Revell 9, or a darker color than the base coat will do the trick. Overthink what effect you want to accomplish. If you base coat would be white, using black to put on a heavy wash, in my o so very humble opinion, it will turn out to be a cartoonlike model. When you don't use enough contrast, it will keep it's plastic or fresh-from-the-factory look.
So: my advise would be: be gentle: you can alwasy put another wash on your previous washes. Well done on starting with the gloss coat!
Good luck!
Posted by ajlafleche on Friday, April 1, 2005 8:41 AM
First, never, I mean NEVER apply an overall wash. That's a surefire way to ruin your paint scheme and decals. Think you're going to wipe off the excess? You're going to smear the wash and absorb the stuff in the crevaces.
Paint thin enough to be a wash is going to spider if shot from an airbrush and ruin your paint an decals. Plus it will dry even faster than when applied by brush. In short, do this and you're (choose your explitive)ed.
Apply the wash at the base of raised details, in panel lines and where two surfaces meet with a fine brush and allow capillary action to draw the wash out. Don't scrub or drag your brush over the model. The solvent can weaken the base coat and make an unholy mess.
Posted by Anonymous on Friday, April 1, 2005 8:15 PM
Hi ajlafleche,
I thought for armour a wash is applied on the whole model to give it a "dirty and weathered look".
Hi svankreijl,
Do you recommend a flat or round brush?
Thanks to both for your replies.Smile [:)]
    August 2004
Posted by Tankmaster7 on Friday, April 1, 2005 8:43 PM
well, it can do that too, but the main point is to bring out details.
-Tanky Welcome to the United States of America, a subsidiary of Exxon Mobil Corporation, in partnership with Halliburton. Security for your constitutional rights provided by Blackwater International.
    April 2004
Posted by crockett on Friday, April 1, 2005 8:55 PM
Gee, I guess I never realized that you never apply an overall wash to your work......never apply an overall wash or your work will turn out like this:
I'm sorry, but I can't disagree more to that advice.
Posted by Anonymous on Friday, April 1, 2005 11:19 PM
For your darkened olive drab you could try a sand colored wash. Kind of a reverse wash. Test it first on the underside to see if it shows up.
Here is a Sherman with artists oil paint wash. Burnt umber on faded olive drab. Brush applied overall and then applied again around the raised details. I allowed it to pool in some areas because thats what I wanted and it collected around all the edges nicely.
Posted by Anonymous on Saturday, April 30, 2005 7:58 PM
All that is ok for armor but what about Navy Aircraft,can an overall wash work?
And why cant a realy heavy thined air bushing do the same as a brush?
    August 2004
Posted by jdavidb on Sunday, May 1, 2005 1:58 PM
an airbrush will just blow the mix all over the place.
This thread seems to have these three things confused: 1.wash 2.drybrushing and 3.weathering. They are different methods with different purposes. So, you've got to know the end result of all of them before you decide which one(s) to do.
Posted by J-Hulk on Thursday, May 5, 2005 11:31 AM
On armor, or really filthy aircraft, a wash over the whole model is fine to both accentuate recesses and to show the accumulation of dirt and grime on the surface. If you don't want that overall grimy look, then you might want to avoid an overall wash.
Personally, I always brush-wash the whole thing (talking armor here) with a dark 'n' nasty "sludge wash." Wiping it off is part of the technique, as you can recreate realistic rain streaks and other grunge effects. The one thing to be careful of is pooling, which can lead to unrealistic effects (or realistic effects, depending on how you manipulate the flow) as the wash dries.
Also, to get the grungy, dusty effect I like, I apply the wash over a flat finish, rather than glossy (which most people seem to prefer, particularly for aircraft). I also use acrylic enamels for my washes.
I would avoid using an airbrush, for the reasons eloquently stated above. But who knows, you might come up with a technique you like!
Happy washing!
~Brian
