Chromed parts, which is the best glue to use?
    July 2004
Posted by timthx on Thursday, June 23, 2005 2:50 AM
HI, I need to find which is the best glue to use when glueing chromed parts together, and also to regular plastic ?
    October 2003
Posted by Daveash on Thursday, June 23, 2005 4:21 AM
You need to scrape off the chrome at the joint and use normal model glue.
Posted by Anonymous on Thursday, June 23, 2005 6:07 AM
What type of parts are you gluing. I ask because you could drill a tiny hole in both parts and put a small small rod to connect them (with a little glue on the rod ends).
