is it good??
is it good??
Posted by Anonymous on Friday, January 24, 2003 7:10 PM
how do painting by using the brush, do i need to mix the acrylic paint with some thinner before i use it with the brush. i have a badger airbrush(100LG), is it a good airbrush??
Posted by weebles on Sunday, February 2, 2003 10:20 AM
HI Web_Boy,
I haven't used a Badger air brush before, but I suspect it's a good one. You will need to think most modeling paints. Look around this site and read all the posts about air brushing. There's a lot of good information.
I would suggest buying a book on airbrushing. I suspect that Kalmbach (Fine Scale Modeler) has some available. Check your hobby store too. That will help you get started.
Dave
Posted by David Voss on Sunday, February 2, 2003 12:15 PM
quote:
Well, since it was mentioned... Smile [:)]
Yes, Kalmbach/Fine Scale Modeler has a book on the subject of airbrushing. It's titled, "How to Use an Airbrush". You can find out more information about it here.
As was also mentioned, I would suggest doing a search within the forums for airbrushing. There's already been quite a few discussions on the subject. If your questions still aren't answered after reading through those discussions, then don't hesitate posting any questions you may have. There are a lot of knowledgeable and helpful people here and I'm confident you'll get the answers you are looking for.
David Voss Senior Web Developer Kalmbach Publishing Co. Join me on the FSM Map
Posted by Anonymous on Tuesday, February 25, 2003 4:22 PM
as far as painting with a brush and using thinner is concerned: try a test strip, I usually brush acrylic paints with a brush straight out of the bottle. But some colors, especially glosses and many laquers are very thick out of the bottle and need to be thinned. If you brush these thick paints on before thinning them it may cover small detail such as panel lines and rivets.
