Washes problem
Washes problem
Posted by Anonymous on Saturday, December 3, 2005 9:21 PM
I get very frustated after i do my washes, i use water  + pastel +dish washing detergent and a bit of top coat , beofre i apply the washes i paint it with future and let it dry. then i apply the washes, after removing the washes, there are mark on my model which i cant remove it completely no matter how hard i try, the stain is still there.. n it mess up my model giving it a very dirty look. any method of washes to give a clean washes that leaves no stain or mark in it?
    December 2003
Posted by thevinman on Saturday, December 3, 2005 10:42 PM
 lizhen wrote:
...i use...and a bit of top coat ...
What do you mean by "top coat"? If your Future finish is completely cured (24hrs), nothing as harmless as water should should stain it.
Posted by Anonymous on Sunday, December 4, 2005 6:08 AM
i mean i added the tamiya x-21 base coat with water n pastel n a bit of washing detergent.
    April 2005
Posted by wing_nut on Sunday, December 4, 2005 7:37 AM
Leave the base coat out.  Water, pastel dust and soap are all you need.  The base coat will make it adhere to the surface.
Marc
Posted by Anonymous on Sunday, December 4, 2005 9:10 AM
ok thanks a lot. i will apply future n then the washes again... :)
    August 2005
Posted by Phil_H on Monday, December 5, 2005 2:05 AM
ahhh....
The old Tamiya Flat base (X-21) issue. It's not meant to be used for anything other than as an additive (in small amounts) to Tamiya gloss paint or clear gloss to give it a flat finish. Don't try to use it on its own as a "top coat" either - all you will get is a powdery white layer on top of your paint. It is merely a "flattening" agent - not a clear coat in its own right.
Someone will probably correct me on this but I think it's 4 parts Tamiya Clear (X-22) to one part Flat Base (X-21) to make a "flat" top coat.
Posted by darson on Monday, December 5, 2005 6:41 AM
No correction necessary Phil, my understanding is a 4:1 ratio as well.
Posted by Anonymous on Wednesday, December 7, 2005 4:30 AM
i am using water plus soap n pastel, but it seem that the pastel dun tend to stick on it.. when i rub if off, the black pastel disappear
    August 2005
Posted by Phil_H on Wednesday, December 7, 2005 7:19 AM
I may be missing something here, but....
Isn't that what you wanted? Your first post said you couldn't get rid of the excess wash. Now you're saying it rubs off.
Well...  It's supposed to rub off the places where you don't want it and stay in the panel lines and around the details you want to highlight. If it's all coming off when you remove the excess then you may be wiping too hard or the rag/cloth/paper towel you're wiping with may be too damp.
    December 2003
Posted by thevinman on Wednesday, December 7, 2005 8:45 AM
Use pastel powder, dry, to simulate smoke and dirt stains etc. (You don't wipe these off, and it's best to do this on a flat coat) - I use a short stiff brush for this.
Use the pastel powder wet (w/ soap) as a wash to get into recessed panel lines. (Here, as Phil_H says, you wipe-off, the idea being, the wash stays in the recessed panel lines.) It's best to do this on a glossy surface (Future). (If you do it on a flat surface, the wash will not wipe off...) - To wipe, I use a Q-tip that is BARELY moist with Windex. If it's to damp, you will wipe the wash out of the panel lines. You can also use a BARELY moist paper towel that is folded and compressed flat, again the idea is you don't want to wipe off the wash in the panel lines.
Both methods take a bit of practice and persistance to get the effect you desire.
Another option is to use a mechanical pencil to draw in the panel lines. Use an eraser if you mess up.
One more tip - If you want to get a FINE panel line. Scribe the line with a slightly dull exacto blade. Then lightly run a pencil across the line. Then rub gently with your finger. The graphite should leave a very fine line behind. Use an eraser if you mess up.
Remember to Future or flat coat after you are done, becuase you might accidentally rub off your work if you handle the model too much.
    May 2004
Posted by albert_sy2 on Tuesday, December 13, 2005 10:20 PM
I've tried them all: sludge wash, pencil, thinned enamel.
My favorite method at the moment is the thinned enamel method.
Thin some Tamiya XF-1 flat black with enamel thinner in a 1:10 ratio (enamel to thinner).
Apply into the area panel lines. Let dry for a few minutes. Use a Q-tip moistened with enamel thinner to remove the excess stuff. Voila!
Groovy baby
    December 2003
Posted by thevinman on Tuesday, December 13, 2005 10:26 PM
 albert_sy2 wrote:
My favorite method at the moment is the thinned enamel method....Use a Q-tip moistened with enamel thinner to remove the excess stuff. Voila!
You are a brave man, albert!
Posted by wibhi2 on Wednesday, December 14, 2005 9:44 PM
I do the same except I use a mixture of very thinned artist oils and enamels. they wipe off very nicely over future and a dampened cotton swab
3d modelling is an option a true mental excercise in frusrtation
    May 2004
Posted by albert_sy2 on Friday, December 16, 2005 2:36 AM
I tried doing the weathering on the underside of a little Corsair. The left side using a sludge wash, the right side using thinned enamel.
The thinned enamel looked better. The pigment went into the panel lines more readily, and the color was darker.
Groovy baby
    December 2005
Posted by Grifter123 on Friday, December 16, 2005 2:30 PM
Artists oils are the way to go.  I too have tried every method out there and nothing performs like oils...not even enamels.  I have also switched to oils for drybrushing, but that's an whole 'nother topic.  I've thinned the oils with white spirit (paint thinner, turpentine, whatever you want to call it) or lighter fluid.  The lighter fluid is nice because it evaporates quickly, but the oils separate from it faster too.  The white spirit works good too, but takes longer to dry and smells stronger.  The oils will stay dissolved in the white spirit longer.
World's Slowest Modeler
Posted by Anonymous on Friday, December 16, 2005 10:43 PM
So you just brush it on then wipe of the stuff you dont after its dried want with a Q-tip?
Posted by Anonymous on Sunday, December 18, 2005 9:42 PM
ya they are so many ways to do it, i have try with pastel adding a slight amount of flat base and future, stirred it well n drybrush on the model, the result came out pretty good, the pastel tend to stick into the model giving it a quite realistic finish.
and mixing pastel with soap and water for washes, i think i musr apply future first then the washes . i have lean quite a lot from this forum , thanks everyone.
