Cutting metal tubing
Posted by Anonymous on Thursday, July 31, 2003 9:49 AM
When you cut metal tubing for guns, how do you do it without pinching the ends?
Posted by berny13 on Thursday, July 31, 2003 10:32 AM
Use fine teeth saw blades. X-acto has some that will fit the small handle. X-acto also makes a razor saw which will also work. After cutting, use a round file to smooth out the end of the tube.
Berny
 Phormer Phantom Phixer
On the bench
    May 2003
Posted by styrene on Thursday, July 31, 2003 11:37 AM
A Dremel tool with a cutter wheel works real well. The wheel Looks like a thin piece of VERY rigid sandpaper, and will go through tubing very efficiently. Available through Lowe's, Home Depot, MicroMark, etc.
Gip Winecoff
Posted by wayne baker on Thursday, July 31, 2003 12:45 PM
When using the Dremel, I hold the piece for the barrel with some pliers, to keep it from flying and it gets hot. Also keeps my fingers away from the cutting wheel.
 I may get so drunk, I have to crawl home. But dammit, I'll crawl like a Marine.
Posted by seaphoto on Thursday, July 31, 2003 1:43 PM
If you are going to cut a lot of tubing, consider getting the motorized cut off wheel sold by Micro Mark (harbor freight also sells a cheaper version that is not as well made). These are by far the best solution for cutting metal rod and tubing up to a half inch or so.
Kurt
Kurt Greiner
Interested in large scale, radio control warships? http://www.warshipmodelsunderway.com
Posted by Anonymous on Thursday, July 31, 2003 1:49 PM
I just slowly roll the tube with a knife on the cork side of a coaster applying a light pressure. The cut I obtain is almost perfect and it can be easily filed with sandpaper or a file. Cheap, effective and very precise!
Posted by Anonymous on Sunday, August 3, 2003 11:30 AM
For fine brass or stainless steel tubing, I use a cut-off wheel to cut it to length. Then square up the cut end and the outside edge with the fine side of an emery board. Finally I clean up the inside of the cut end with the point of an old #11 blade. All very easy. Wink [;)]
Pete
Posted by Anonymous on Sunday, August 3, 2003 6:04 PM
thanks so much for all your tips! I dont have a dremel so i think i'll try one of the manual saw/cut methosds. Wish me luck!
Posted by Anonymous on Sunday, August 3, 2003 7:02 PM
QUOTE: I just slowly roll the tube with a knife on the cork side of a coaster applying a light pressure. The cut I obtain is almost perfect and it can be easily filed with sandpaper or a file. Cheap, effective and very precise!
This exactly how a tubing cutter and even large power pipe cutters work. The tubing is rolled between a blade and an anvil, this leaves a small ridge in the ID of the tube but it can be easily removed.
Posted by Anonymous on Sunday, August 3, 2003 11:09 PM
I bought one made by K&S at the train shop. It looks like a full size pipe cutter but is made for 1/32 to about 3/4 of an inch. I can send a pic if you would like. It cuts straight and smooth.
