Problem with wash technique !
Posted by Anonymous on Thursday, August 28, 2003 1:04 PM
I am trying to use the wash as written in Nov.2001 issue of FSM. I have followed the directions precisely. I sprayed Future before using the wash. My problem is that I cannot remove excess from panels where the wash is not wanted. What could be the problem? MartyM2828
Posted by Moses on Thursday, August 28, 2003 2:05 PM
What medium are you using for the wash? Is it Acrylic, Enamel, or Oil. If you are using Oil (my favorite), you will need to apply your wash, then using a cotton swap dampned with thinner..you can remove the wash from places where you want to remove it from. Not sure why you couldn't remove it. Did you remove try to remove it right after you applied the wash, or did you allow it to dry?
"ZIM FIRST, ASK QUESTIONS LATER!!"
Posted by Anonymous on Friday, August 29, 2003 11:54 AM
I am using acrylic for the base of the wash. I tried to remove the excess wash after it dried (maybe 10 min.). The article mentioned removing the excess after it had dried as well. I was using just water and a Q-Tip at first to remove but then I tried alcohol and that wanted to lift my paint job. MartyM2828
Posted by maddafinga on Friday, August 29, 2003 12:54 PM
Sounds like maybe you could use a bit more dish soap in your wash mixture. I use that sludge was, and found I needed a bit more soap, after adding it, it comes off just fine for me. I use a damp q-tip to remove it. Try putting a bit more soap in, a few drops at a time, and test on an old model or something. keep adding until you get it where you want it. Hope everything works out for you, no matter what method you end up using.
madda
Madda Trifles make perfection, but perfection is no trifle. -- Leonardo Da Vinci Tact is for those who lack the wit for sarcasm.--maddafinga
