Bare-metal foil
Bare-metal foil
Posted by Anonymous on Thursday, October 9, 2003 11:16 PM
After I have stuck down my bare -metal foil and then painted the part I can't get the foil off without it breaking into lots of little pieces and then I end up scratching the part trying to pick it off with a knife. Is this normal or is there alot easier method which I am not aware of.
Posted by Anonymous on Friday, October 10, 2003 8:17 AM
I have the same problem. A long fingernail looks odd but it's an indispensible tool! Try to lift a corner with a piece of tape, just keep it off of the paint. If you have to pick at it, sharpen a toothpick or an old paintbrush handle to a fine point and use it instead of an X-acto blade. Honing it on fine sandpaper will make it needle sharp.
-fish
    January 2003
Posted by leemitcheltree on Friday, October 10, 2003 10:52 AM
Try a toothpick sharpened to a chisel point - it won't scratch the clear plastic like an X-acto blade will..........
I've never had problems removing the foil after painting - just make sure you remove it as soon as you can. the longer you leave it on, the more adhesive is left behind when you take it off.
Cheers
LeeTree
Cheers, LeeTree
Remember, Safety Fast!!!
Posted by Anonymous on Sunday, October 12, 2003 10:35 PM
i use a pair of presicion tweezers to remove bmf. and i will echo what lee tree said, dont wait to long to remove it, i've used this method before and have found out by trial and error (more error ) that if i only use a thin peice of foil then use masking tape over the foil but just shy of covering the edge and then pull this off after only a few minutes of drying time i get a nice even line. hope this helps you out.
