Stripping Paint with Windex (is it possible)
    December 2006
Posted by J West on Saturday, October 20, 2007 12:47 PM
I have a KV2 that has been painted, however I am not happy with it and want to start back at square one. Usually I use CSC, but currently do not have any. It is painted with tamyia acrylics and over coated with future. I know windex will remove freshly sprayed paint, but this model has had several months to cure and so I am unsure of what will happen. Does anyone have any advice? I figure it probably wont hurt it regardless, but am not sure.
    May 2005
Posted by Bgrigg on Saturday, October 20, 2007 12:50 PM
Windex will soak it off. It may leave some residue, but the vast majority will come right off.
So long folks!
    January 2007
Posted by IYAAYAS on Saturday, October 20, 2007 1:39 PM
most likely it will work with a little "Persuasion" from a tooth brush of the like.
    January 2003
Posted by Triarius on Saturday, October 20, 2007 1:56 PM
Sign - Ditto [#ditto]
    August 2007
Posted by ben1227 on Saturday, October 20, 2007 2:10 PM
I agree, it may require a little scrubbing in places since the paint's sat on there that long.
.:On the Bench:. Tamiya 1/72 M6A1-K
    October 2004
Posted by jschlechty on Sunday, October 21, 2007 3:56 PM
Yup - it'll soak off paint, Future, decals, everything if left in it long enough!  The only problem is getting a contianer big enough to be bale to cover the model with windex.  If you don't want to use that much WIndex, you could do it one side at a time and turn it over, etc. . .
    August 2007
Posted by ben1227 on Sunday, October 21, 2007 6:43 PM
Yea, it'd take a LOT of Windex. It may take 2-3 of the big Refill size jugs.
    December 2006
Posted by J West on Sunday, October 21, 2007 7:18 PM
***Update***
I attempted the windex paint removal this evening. I had only a 1/3 of a spray bottle of windex, so I placed the model in a disposable tupperware type container and started spraying it. After a good coating, I left it for five miniutes while I left the room as I dislike the smell of windex. On returning I sprayed more on it and watched as the paint washed right off. I have never had success like this even with CSC as it always required a soaking, however this had the paint removed down to the primer almost immediately.
    August 2007
Posted by ben1227 on Sunday, October 21, 2007 7:47 PM
I thought it'd work...
    May 2005
Posted by Bgrigg on Sunday, October 21, 2007 9:15 PM
Good news!
I never even attempted to just spray it on. Banged Head [banghead]
I use Windex for cleaning my AB and save the residue in a large jar for soaking bad paint jobs in.
So long folks!
    August 2007
Posted by Grampa on Tuesday, October 23, 2007 6:51 AM
Does Windex work on enamel?  How about Lacquer? Question [?]
Jerry
You can never have enough Corsairs!
    January 2003
Posted by Triarius on Tuesday, October 23, 2007 8:59 AM
No, Jerry, acrylics only.
    August 2007
Posted by Grampa on Tuesday, October 23, 2007 9:27 AM
Thanks for the info, Ross
Jerry
Posted by mass tactical on Tuesday, October 23, 2007 12:13 PM
91% Isopropyl Alcohol works great on removing Tamiya paints.  A short soak will loosen it right up.
Posted by MikeV on Tuesday, October 30, 2007 2:49 PM
 J West wrote:
***Update***
That is interesting as Super Clean has worked far better than anything I have ever tried.
    December 2006
Posted by J West on Tuesday, October 30, 2007 4:33 PM
I was surprised by it as well. It was not a very heavy layer of paint + future on the model so that may be part of the success, another maybe in the difference of paint vs. primer. The model was spray primed with Citidel Chaos Black primer which was not disturbed at all by the windex. There may be a poor adhesion between the paint and the primer?
Posted by MikeV on Monday, November 19, 2007 3:20 AM
Jerry
Jerry,
For enamels and lacquers use Super Clean or Easy Off oven cleaner (yellow can).
Here is a good read: http://www.bonediggers.com/1-3/strip/strip.html
Posted by espins1 on Monday, November 19, 2007 1:51 PM
I've never had any problems using Windex to remove acrylic paint.  Even paint that was on for 2 years came off in moments with a couple of spritzes of windex and a rinse in water.
Scott Espin - IPMS Reno High Rollers  Geeked My Reviews
    December 2007
Posted by warmaster on Tuesday, January 1, 2008 4:29 PM
I came across this thread and read it eagerly because I have made some painting mistakes and wanted to strip off the paint and start over. After reading the suggestions, I used some denatured alcohol I had around and a few minutes in that and scrubbing with a toothbrush worked wonders on acrylic paint. Chalk up another alternative!
"Not a soldier, just a patriot."
    August 2006
Posted by HawkeyeHobbies on Thursday, January 3, 2008 4:20 PM
Spontanious Stripping Tank....err bag!
I needed to strip the paint off a set of wings I had pre paint then changed my mind about the scheme. Dumped a little Windex and some Simple Green into a Ziploc bag...bingo it only took a few minutes. Poured the mix back into the storage jar and I was done.
Gerald "Hawkeye" Voigt
    February 2004
Posted by rrmmodeler on Tuesday, January 22, 2008 4:41 PM
I have had no problems using Windex to striping acrlyic paints. Its definitly a save way to strip clear parts. I had a canopy painted up on a old mothballed project. I needed a new one for a new project so I took the old canopy and dropped it into a cup of Windex. The canopy had been painted two years before, and futured. In no time the canopy was like it had just came out of the box. After the paint was gone I washed in with some warm water and I had a new canopy ready to be futured and painted.
    January 2008
Posted by Red Comet on Sunday, January 27, 2008 6:15 PM
I'm a big fan of using window cleaner for stripping acrylic paint too. In fact, I wrote a tutorial on how to do it :
http://www.ghostofzeon.com/diy/paintstrip/paintstrip.html
Hope you all find this of help! Big Smile [:D]
    July 2013
Posted by modelmaker66 on Thursday, February 18, 2016 4:08 PM
you can strip newly painted items painted in acrylic with windex. for set up acrylic i simple green. Spray on, wait a few min. scrub with toothbrush, rinse  and repeat as necessary. never let it set very long though so i cant reccommend that
