Raised Panel Lines
    October 2003
Raised Panel Lines
Posted by yf23 on Saturday, October 18, 2003 2:52 PM
Have several models with raised panel lines and read that they can be removed and replaced with engraved panel lines, but the article did not say how to do this, anyone who knows how to do this your info would be greatly appreciated.
Posted by djmodels1999 on Monday, October 20, 2003 2:09 AM
You can buy re-scribing tools from any good model shop. You'll need some 'template' tool too, in order to get decent straight lines and curves. Several photoetched bits manufacturers market those.
Posted by Anonymous on Monday, October 20, 2003 2:16 AM
First you clear these lines of, using thin sand paper. Then you pass them over with liquid glue, this will make them reappear in the form of an engraved line (in the best case) or as a different colored line. Using the tolls mentioned above and maybe scale plans of the subject you re-scribe panel lines. One more pass with liquid glue will clear the engraved lines. After glue completely dries, you sand with a very very thin sand paper, and... there you are!
Posted by Woody on Monday, October 20, 2003 2:52 AM
A trick I like to use is to get the pinvise out and where the raised lines intersect, drill shallow holes the width that the engraved lines will be. Now get your straight edge out and connect the dots! Wink [;)]
" I wish to have no connection with any ship that does not sail fast; for I intend to go in harm's way." --John Paul Jones
Posted by Anonymous on Wednesday, October 22, 2003 3:46 AM
well i was a raised line hater until i made a heller raised kit .
the weathering in the raised lines was of my liking and now i like them too. on the plus side no need for scribing...lol
Posted by BlackWolf3945 on Thursday, October 23, 2003 4:32 PM
Here's a how-to on a slightly different way to engrave lines from my much-neglected website...
Fade to Black...
