Hi all
    November 2008
Hi all
Posted by Amit33 on Tuesday, November 4, 2008 4:14 AM
My name is Amit and I'm new to this models hobby.
I've bought a ship model of Revell and i would like to ask few questions:
1. Should the Revell colours be mixed with something or just used as they are?
2. How much should I wait until the paint is dry?
3. On the outside cover of the model there were 4 colours (bought them all) but in the inner instruction page there are much more. Why is that? Should I buy them all?
Thanks a lot :)
Amit.
    September 2007
Posted by firesmacker on Tuesday, November 4, 2008 7:53 PM
Amit,
Sign - Welcome [#welcome]
The instructions will tell you what ratios to mix the colors. Mixing of colors is one reason why you see so many different ones in the instructions. What kit are you building? Knowing that would help folks here give you a reccomendation on what colors you really need. In my opinion, as long as those 4 colors are hull grey or light grey, hull red or an equivalent, flat black and maybe a tan if the ship has wooden decks, you should be fine.
One last thing, use the search function in the Ship forums. Many questions you have can probably be answered there. Hope this helps.
Regards,
Jeff
    September 2004
Posted by Borg R3-MC0 on Wednesday, November 5, 2008 6:14 AM
What type of Revell paint do you have?
If it's the enamel, you might want to thin it a bit with white spirit.
If it's thier newer acrilic paint, thinning is not necassery beofre painting. But if you want to, you can, using water.
Paint is often dry to tuch in 6 hours, some people recommend waiting 24 hours so the the paint can cure.
The paint named on the outside are the major colors for the scheme. The paints in the instructions are also the paint colors for the small details.
