painting tips
    November 2008
painting tips
Posted by plumline on Saturday, December 6, 2008 8:43 AM
   Hello all, can you offer some tips on using a spray can to it's best advantage.thanks in advance
A man with an experience is never at the mercy of a man with an argument.
    May 2005
Posted by Bgrigg on Saturday, December 6, 2008 9:02 AM
Shake, shake, shake, shake, SHAKE, shake, shake and then shake. Then shake some more. Especially if you are using metallics.
And before doing that place the can in a bowl of warm (NOT HOT) water. The propellant used causes the can to freeze which slows down the paint. Spray until the can starts to feel real cold, then put back into the warm (NOT HOT) water. Repeat as necessary. Don't forget to shake.
Use light coats, start spraying before the model and end after the model. Don't forget to shake.
And only use in a well ventilated area. A respirator is highly recommended. Don't spray around little kids. And don't forget to shake!
So long folks!
    November 2008
Posted by plumline on Saturday, December 6, 2008 11:18 AM
  Just so I understand I shake the can right. :)
dmk
    September 2008
Posted by dmk on Saturday, December 6, 2008 11:34 AM
 Yes, shake the can. Shaking the model is definately not recommended.  Big Smile [:D]
 Be very careful not to put coats on too heavy. This is very easy to do with a paint can (and a big advantage to using an airbrush).
  Spray from a bit of a distance away from the model (at least 6", maybe more) and put on only a light coat. Don't worry if it doesn't seem like it's covering the previous color. Every light coat adds up and eventually, with patience it will cover just fine. Let the previous layer dry a little before you put the next layer on. The wait time is quicker with flat paints (just a minute maybe) than it is with gloss paints (maybe 5 to 10 minutes). Don't try to do it all in one session. Be prepared to come back the next day and put a second coat on, and maybe even the day after that.
 Remember, you can always add another coat, but if you put it on too thick, cover details and/or get runs in the finish, it is very difficult to fix.
   Every can is slightly different, so when you start to spray, paint a little bit on a piece of cardboard or an old soda bottle or something to get a feel for the pattern of the nozzle and the distance required for a light coat.
 Primer definately helps. Something like a light gray overall will give you a consistent color that is easier to put your top coat on when painting light colors.
 You need to get good with using masks on the model for the camo or different colored sections. Painters tape is good for square and large sections, for curved and smaller sections, Tamiya tape, flexible 3M 1st Aid tape, Silly Putty, etc can really help. Paper and plastic bags can be used, along with painters tape to mask off large sections.
 Oh yea, and shake the can too.  Smile [:)]
    May 2005
Posted by Bgrigg on Saturday, December 6, 2008 11:47 AM
Jeeze, did I forget to mention that? Wink [;)]
So long folks!
    May 2005
Posted by Bgrigg on Saturday, December 6, 2008 11:49 AM
Oh, and keep away from cats.
Cats don't like to be spray painted.
So long folks!
    November 2008
Posted by plumline on Saturday, December 6, 2008 12:36 PM
  Don't have any cats but I do have a dog Smile [:)] how do you use the face symbols
    October 2007
Posted by Milairjunkie on Saturday, December 6, 2008 12:48 PM
Don't forget to shake the can!
Also, the further you get into the can, the less it will like being held off vertical. If you Keep the can at an angle there is the chance that propellant will be pushed through the feed tube & into the nozzle rather than paint - this will leave you will big spatters on your job, which is not nice.
Remember to shake the can!! It is also advisable to hold your work in your hand while spraying, but dont use latex or ploy gloves for obvious reason's.
    June 2008
Posted by Hans von Hammer on Saturday, December 6, 2008 1:20 PM
It helps to warm the can in some hot water for about 10 minutes, water about the temp of a cup of coffee.. It helps atomize the paint a bit better... Make sure you don't heat it on the stove tho... A pan of hot water sittin' on the bench is preffered..
    November 2008
Posted by plumline on Saturday, December 6, 2008 1:44 PM
  why is holding the model in my hand better than on a flat surface or a stand made for painting.
dmk
    September 2008
Posted by dmk on Saturday, December 6, 2008 2:58 PM
Because you can rotate the piece or the model in three dimensions as you paint it. That allows you to get good coverage in recesses and around the bits and pieces sticking out.
 The trick of course is to plan how you will be holding the parts, so that you can pick it up and rotate it, but then put it down again to dry without any of the painted surfaces contacting anything. You can get creative with rolling tape sticky side out to attch parts to ice cream sticks, bamboo skewers, wire coat hangers, pieces of wood scraps, whatever you have laying around. For jets, I save old paper towel rolls, slit along one side lengthwise, then roll it tightly around a wooden dowel. Insert this in the tailpipe to act as a handle for the model. It will try to unwind itself and provide a little tension to hold it in. You can wrap some tape around it if necessary. I have a vice on my paint bench to hold items such as this when I'm not handling them.
OK, that's not so obvious to me. Why not use gloves? I always use Vinyl or Nitrile gloves when painting to keep paint off my hand and to keep oils from my skin off the model (which I clean with alchohol before painting).
Unless you were joking, then excuse my denseness.
From what I can tell, dogs don't care. Maybe because they don't have to lick it off. Tongue [:P]
    May 2005
Posted by Bgrigg on Saturday, December 6, 2008 3:20 PM
Depending on what your painting, it's a lot easier to move the model around while keeping the can vertical. I'm not sure why Milairjunkie says not to use latex gloves. I do with no problems. You do need to find the "dustless" ones so the cornstarch that is used in most latex gloves doesn't contaminate your paint job.
You can buy paint stands such as these ones, or you can make your own. I built one like the one on the right (mine's taller) using a small pieces of 2"x4", some clothes hangers and a dowel. It hold auto bodies very securely and allows me to rotate it around as needed.
I also built a rotating stand for aircraft and armor which you can see in this thread: /forums/1/545933/ShowPost.aspx my stand is about 2/3rds down the page.  This stand can be used for painting, decaling or assembly.
So long folks!
dmk
    September 2008
Posted by dmk on Saturday, December 6, 2008 3:28 PM
Or just put the gloves on, then wash your hands with handsoap and hot water (The warmer the water, the faster it will dry without you needing to dry them with a towel or something that will get lint and dust on them).
    October 2007
Posted by Milairjunkie on Saturday, December 6, 2008 5:23 PM
Sorry Guys, I was having a laugh - the question brought me back to my first attempt at spraying a model, an Audi Quattro in gloss white, when I was about 8.
I cant remember what type of paint it was, but I imagine it would have been enamel. You can imagine the mess, my hand & fore-arm were white for days - the model, it was rapidly fired into the "to repair or rework - never" container.
    November 2008
Posted by Mixael on Sunday, December 7, 2008 5:53 PM
The reason for not using the latex gloves is simply that SOME paints and propellants in spray cans isn't compatible with latex gloves (it eats them).  So, instead of protecting your hands, you're melting latex to them, THEN painting your hands.  Actually a pretty cool effect - if you spray the gloves when you're NOT wearing them!  As a rule of thumb, if the paint has a strong solventy smell, it will probably attack the latex.  (Nitrile is supposed to not have this happen, and I don't know about vinyl.)
I learned this at work once when I was spraying some paint on a pump housing, and my gloves went bye-bye in front of my eyes Smile [:)]
Michael
We could change the world, but God won't give us the source code!
    November 2008
Posted by Mixael on Sunday, December 7, 2008 5:57 PM
Smile,Wink, & Grin [swg] MY first attempt at using spray paint ended up with more paint on my hands than on the model.  I had a hard time explaining why my hands were blood red, though!
Michael
dmk
    September 2008
Posted by dmk on Sunday, December 7, 2008 6:17 PM
Ah! Good to know. I figured it was something like that.
    November 2008
Posted by plumline on Sunday, December 7, 2008 6:22 PM
   thanks for the info, one more question at the local hobbie shop I noticed testors has what looks like an air brush kit that attaches to a spray can have you seen that. It looks like a poor mans air brush system. Yes there is one more question any truth about turning the spray can upside down to clean out the paint from the tip. Is it a good idea when it comes to painting models.
    June 2008
Posted by Hans von Hammer on Thursday, December 11, 2008 12:19 PM
It is.  It's only slightly better than a spray can in that you can mix your own colrs.  Otherwise, it's a bust...
It's true and will save you some clogged nozzles on expensive paints.
    February 2007
Posted by Bioya on Thursday, December 11, 2008 1:28 PM
Most spray cans have removable nozzles. When you find the ones with a nice spray pattern, use them and store them in a capped jar with thinner to keep them clean (after you have turned the can over to spray propellant through them). Heating up spray cans with warm water also helps.
    June 2008
Posted by Hans von Hammer on Thursday, December 11, 2008 4:10 PM
Most likely the cuprit was laquer... Enamels and acryllics don't bother latex...
    February 2006
Posted by Wilbur Wright on Friday, December 12, 2008 12:36 PM
Placing a rattle can in a pan of water as hot as coffee which was previously posted (which is near boiling point) could make the can explode.
You can put it in warm water for 10 minutes, however be warned that the atomization will thin the paint out and it will come out faster much more liquid and will be prone to drips if applied in anything but light coats.
