Painting Raised Text on a Base
    July 2008
Posted by Greasy on Tuesday, December 9, 2008 11:40 AM
I am working on my Star Wars Battle Droid with STAP.  It has been a fun model so far. While letting some paint dry, I was looking at the base and I got puzzled on how to paint the raised letters.  I know I want the Base Black while the text is either a Gold or Bright Yellow.  I am leaning more toward the yellow.
http://www.happinessismandatory.com/misc/Models/AMT_Battle_Driod/General_Images/Spure_Stap_3.jpg
My Ideas
1) I though about masking but the bold letter of Star Wars is not a problem but the little letters of "The Phantom Menace" would be a paint. Also I masked should it be tape or liquid.
2) Spray the hole area Gold/Yellow let dry and spray with a clear coat and dry. Then spray the whole base back and let it semi-dry and use a Q-tip with school (I use acrylics) and rub the black off. The just seems too easy to mess up. And the black with the Gold/Yellow under it may not match. Not sure about that though
3) Do like step two but let the black dry and use fine sand paper to remove the black. I think the best to far, but I need to be heavy with sand paper.
What do you think? Or how have you done it in the past?
Thanks,
Jon
    January 2008
Posted by acmodeler01 on Tuesday, December 9, 2008 12:01 PM
You could paint the base first with the yellow but use a laquer and let it dry thoroughly. Follow that up with a coat of acrylic (water-based) black that you could wipe off while wet or sand down a bit when dry. I would do it that way, wiping the black off with a cloth or something to get most of it off, then once it is dry, use a q-tip or something dampened with 91% alcohol to get the leftovers. Let us see the results... I have the same kit and I'd liek to see how your ideas turn out.
    June 2008
Posted by Hans von Hammer on Thursday, December 11, 2008 12:15 PM
I'd pre-paint the lettering....
