I started with a single action changed to a combined dual action and use now a dual action.
I agree with Dave you have a big learning curve with a dual action, but I believe you have better control over your paintjob. But also more can go wrong.
Good alternative is the combined dualaction sold by Hansa. As you pull back the lever the air starts to flow and pull it more back the air will mix with the paint.
I have no problem with cleaning both guns. I strip the guns after I finished spraying, and when using metallic paint I strip them in between.
The metallic will clock up the nozzle when used with the .15 nozzle.
