Okay, i'm sure someone has asked these questions before, but i'm too tired to go and hunt them down, so please humor me.
First, when and how do you use primer (i've never tried it before because i always thought it was just normal gray paint)? Do you use it only for when you airbrush or can you use it for brush painting? Also, should i assemble the major aircraft sections together before spraying? How thick should the coat be?
Secondly, does anyone have a website with a step-by-step of how to properly apply bare metal foil (maybe swanny...
)? I'm kind of worried how it will handle around complex curves... Also, will bare metal stick to tamiya's plastic/metal gray primer?
Thanks, guys!!
