Iwata Cleanout Jar
    December 2005
Iwata Cleanout Jar
Posted by JamesDean on Wednesday, April 14, 2010 10:24 AM
I've got an old Testors/Aztek cleanout jar which works fine with my Badger 200, but my new 105 doesn't "fit".  The color cup gets in the way and I cant insert the 105 far enough into the socket on the clean out jar.
I was looking at the Iwata cleaning station but when I saw this picture I wondered if I might run into the same problem, only this time with the air line preventing it from going all the way in.ne.
   Has anyone ever run into this?
    April 2004
Posted by keilau on Thursday, April 15, 2010 8:47 PM
JamesDean
You are right! The Iwata cleaning station is for the Eclipse ONLY like shown in your picture.
The Badger Patriot is too short, so is the Harder & Steenbeck Evolution.
Don't feel bad. The Iwata Custom Micro C+ will not fit either because the MAC value gets in the way.
Posted by MikeV on Thursday, April 15, 2010 10:39 PM
Just make your own and save some money!
Posted by Wingman_kz on Friday, April 16, 2010 1:04 AM
Didn't your Testors jar come with two different tubes/inlets? One is kinda like a basket,  for lack of a better description, that you have to insert the brush into quite a ways and the other is solid tube with a little rubber cap where you insert the brush. Using the latter all you insert is the very tip of the brush kinda like the Iwata version pictured. Been so long since I changed mine I don't remember whether the tubes screw in and out or if they snap in and out. Mine came with both.
Tony
    December 2005
Posted by JamesDean on Friday, April 16, 2010 5:29 AM
Thanks for the feedback.  You've saved me from a 30 disappointment.
"Didn't your Testors jar come with two different tubes/inlets?"
<sigh> It was a hand-me-down from a friend.  I've only got the "basket" inlet.
Posted by Torio on Thursday, April 22, 2010 7:28 PM
Well, chaps , I tried on my own and disagree a little with your conclusions, as for Harder & Steenbeck be it Evolution or Infinity, they enter enough not to mess the workbench and it's all I ask for, BUT I couldn't engage correctly :
Efbe B1
Aerograph De Vilbiss Sprite and Super 63
Gabbert PRS
Badger 100
Sotar
Badger Patriot engages a bit too shortly
As for Iwata, I tried  CM C+, HP CH and HP CR (this latter known as Revolution) and I think the settling is correct and that the MAC valve is not interfering
But all this is very subjective
In any case, you can choose other products ( there is another one with a very heavy glass jar) or build one yourself as Mike suggested.
By the way, did you notice this stuff is labelled Sparmax ?
Thank you all for coming José
    April 2004
Posted by keilau on Thursday, April 22, 2010 7:55 PM
Torio
I can use any airbrush with it if I remove the upper fork holding the airbrush and hold the airbrush by hand. In that case, I would rather spray cleaner into an empty milk bottle.
Sparmax makes quite a few items for the Iwata brand, but no airbrush.
