- Member since
December 2004
Teflon Tape and Compressor!
Posted by panzerpilot
on Thursday, August 25, 2011 7:07 PM
I put teflon tape on the threads of my compressor hose connections today. It's the same stuff you can buy at Home Depot for shower heads. A 1/4 inch wide strip wound one time around, in the direction of twist, for the large connection of the hose. A tiny strip, cut with my #11 blade for the other end at the airbrush connection. Anyway, my compressor does not cycle now unless it is used. It is holding the pressure THAT good. I thought I'd let you guys know, since this cuts wayyy down on the pressure cycles, noise, ... and wear!
