Super CHEAP, ridiculously FAST! Paint remover
    January 2007
Posted by the doog on Monday, September 26, 2011 2:18 PM
Hey guys, I want to tell you about an amazing product that I found that does what Simple Green does--but better, and at about a quarter of the price!
While working on a tank model, I went out to buy some "Simple Green", which I've learned about in Auto Modeling--it works wonders in stripping paint.  It works for both Tamiya acrylics and spray paints. The only downside is that the stuff ain't cheap--like, $8.00 for 20 oz! And you need about 30 ounces to really make a good sized "bath". I found some in a hardware store for $7.49/bottle, but since I was on my way to Walmart, I decided to see what they had.
They didn't have any "Simple Green", but they did have "Mean Green". It looked like a similar product to me. On the back it had that warning "Do not use on painted surfaces". HMMM? Could it work the same? Geez. for $1.79 a bottle for 40 ounces, how could I go wrong?!
I got home and put the model in the bin, and started pouring--holy cow!--as soon as I started to pour the stuff on the model (which had been airbrushed with Tamiya acrylics) the paint literally started to wash right off! In the photo, I had Jenn grab the camera and shoot as I was still pouring out the liquid--the hull there has already been taken down to the gray Duplicote primer, and the Coelian turret has already lost most of its green topcoat, exposing the Dark Yellow underneath! The Dark Yellow came off a few minutes later--I easily just brushed it off with a soft brush, no problem! This stuff is AMAZING!--and CHEAP!
I haven't tried it yet on enamels or other paints, but if you use Simple Green, I'm betting this will do what you need it to do--at a quarter of the price!! AND it's biodegradable, just like Simple Green! Take it away, spokesdoog! Big Smile
    July 2010
Posted by Echo139er on Monday, September 26, 2011 2:24 PM
Excellent!  I am running low on SG!  I think I'will try this out BEFORE i buy more SG.  Thanks for the tip!
    November 2008
Posted by mrmike on Monday, September 26, 2011 2:40 PM
Great tip...looks alot more friendly than brake fluid. Thanx!
Posted by RESlusher on Monday, September 26, 2011 3:00 PM
I've been using Windex...both name brand and store brand equivalent!
I think I might have to give this stuff a try!
Thanks for the info!  Toast
Richard S.
On the bench:  AFV Club M730A1 Chaparral
On deck:  Tamiya Marder 1A2
In the hole:  Who knows what's next!
    August 2007
Posted by DUSTER on Monday, September 26, 2011 3:30 PM
Thanks the dog & spokesdoog Yes
As a "simple" modeler have been using Simple Green for a while now, but your results do give me cause to consider changing.
 Anyone have a report on Mean Green and how it works on Alclad II and/or enamels?
Steve
itz
    August 2011
Posted by itz on Saturday, October 1, 2011 7:40 PM
Hi,
I'm new here and have just started modeling againn after a 25 year break. My Hasegawa !:48 spitfire came out great except that i would like to strip the paint off one wing as it sprayed on too thick and detail was lost. What can I use for Enamel paint And layers of gloss and dull caot?
Thanx so much in advance.
    August 2011
Posted by GreenThumb on Saturday, October 1, 2011 8:50 PM
itz
Hi,
Two of the best products to remove enamels is Super Clean degreaser and Easy Off oven cleaner in the yellow can. With the Super Clean the part needs to be submerged to work best and Easy-Off works best when sprayed and left in an airtight bag or container so that the fumes can work on the paint. Both contain Lye which is caustic but safe if used according to instructions.
    August 2007
Posted by DUSTER on Monday, October 3, 2011 11:40 PM
itz
Hi,
I have had good results with Simple Green, (soaking the part or model in the product as long a necessary (over night in many cases , brush with an old tooth brush  and rinse) it has a lower toxicity rating compaired to the oven cleaner, brake fluid,etc, types. However as the topic of this post suggests-  Mean Green may do the job as well.  The good part is you get to experiment and we get the results Angel Whistling
Steve
    April 2004
Posted by Jon_a_its on Tuesday, October 4, 2011 4:02 AM
So who makes Mean Green?
over this side of the pond we can't even get Simple Green!
East Mids Model Club 32nd Annual Show 2nd April 2023
 http://www.eastmidsmodelclub.co.uk/
Don't feed the CM!
    August 2007
Posted by DUSTER on Tuesday, October 4, 2011 10:32 PM
Jon_a_its
2 cents
http://www.simplegreen.com/about_us_global_partners.php
http://www.meangreencleaner.net/Home.html
 Geeked
Steve
Posted by waikong on Wednesday, October 5, 2011 11:52 AM
Wow, that's great information, thanks very much for sharing it,
    July 2011
Posted by prush on Wednesday, October 5, 2011 12:07 PM
Will it remove paint bleed from clear parts without fogging/melting the clear parts?
    April 2008
Posted by zapme on Thursday, October 6, 2011 4:30 AM
Hi doog,
Are the Simple Green and Mean Green just standard detergents as i can quite read the label on the pics.
Thanks
Leo
My Blog - leoslatestbuilds.blogspot.com
On the workbench: 1/72 Airfix De Havilland DH88 Comet , 1/35 Trumpeter M1A1, 1/35 Tamiya Tyrannosaurus Rex, 1/8 (?) vinyl C3PO brand unknown
    July 2011
Posted by BBAT222 on Thursday, October 6, 2011 12:14 PM
Thanks for the tip Karl.  I'll give it a try.   I use the Simple Green in with the Future to help level and shine.  I will give the Mean Green a go here also.  The pic's are impressive.    Thanks again   Buddy B.
http://farm6.static.flickr.com/5304/5648056204_9a52bddd15.jpg
    August 2011
Posted by GreenThumb on Thursday, October 6, 2011 6:52 PM
zapme
Hi doog,
Thanks
Leo
Yes they pretty much are. They are biodegradable though which is a good thing.
Especially for those of us who work in very "green" cities. Wink
    January 2007
Posted by the doog on Thursday, October 6, 2011 7:16 PM
Glad to pass on the info, guys--I"m sorry I couldn't answer all the questions, but I just don't know...uey....
If anyone garners anymore info or experience with this stuff, please post it here!
Thanks, guys!
    July 2011
Posted by BBAT222 on Saturday, October 8, 2011 11:11 PM
Well Karl I'm going to get to try mean green sooner than I had hoped to.  I used Testors flat enamel for the bottom of the p-51 and then  (to much pain killer) after some filler touch-ups sprayed the bottom with auto primer! Aaaa!   I'll let you and the rest know how it did with the enamel.   GB   Buddy B.
    July 2011
Posted by BBAT222 on Sunday, October 9, 2011 9:02 PM
Ok Karl.  I tried the Mean Green on the auto primer over Testors flat enamel, and it didn't do a thing.  So back to the rough stuff for this project.  I did use paint thinner which removed the auto primer, but not the flat enamel.  See ya latter mate.    Buddy B.
    January 2007
Posted by the doog on Sunday, October 9, 2011 9:08 PM
BBAT222
Hey Bud,
Thanks for posting your results here. Enamel and lacquer is a tough call. Once they harden, they're tough as nails.
Thanks too, everyone weighing in. Well, at least we know it removes acrylics with lightening speed!
    August 2011
Posted by GreenThumb on Sunday, October 9, 2011 9:54 PM
Bud,
Both Super Clean degreaser and Easy-Off oven cleaner will remove enamels.
You may need to soak it for several hours and scrub with an old toothbrush but it will strip it eventually.
    August 2007
Posted by DUSTER on Sunday, October 9, 2011 11:35 PM
GreenThumb
Bud,
Time is your friend with any of these simple/mean green products. The older/dryer the paint the longer it needs to soak.  Have waited for up to 48 hours on one stubborn @$%$  uh- difficult little monster; each try, "some" paint came off- layer by layer. Eventually , though, it all came off.
Steve
    September 2011
Posted by Centhot on Monday, October 10, 2011 11:35 AM
Nail polish remover.  Large bottle, costs peanuts, lasts ages, and is instant.  Takes off all paint, and leaves the plastic perfect.  Brilliant.  The last bottle I bought was about $1.50 some months back.  Usually use tissue soaked in it, then rub down the model.  When tough, I use an old toothbrush, and 2-3 applications.
It has another application.  It removes excess filler.  On a recent build, where there's excess filler where the fuselage meets the fin, I used a cotton ear-bud, soaked in nail polish remover, and rubbed it along the seam.  Took quite a while, to be honest, but the finish was better than sanding alone (I did some sanding).
In my view, along with Future/Klear/Pledge everyone needs a bottle of nail polish remover!
2012 A/B/C: 10/3/0 (Acquired/Binned/Completed)
    August 2011
Posted by GreenThumb on Monday, October 10, 2011 1:20 PM
Centhot
I would be real cautious with nail polish remover as it contains acetone which is pretty harsh stuff especially on clear plastic. Super Clean is much less toxic smelling and does a great job.
    September 2011
Posted by Centhot on Monday, October 10, 2011 1:48 PM
Never tried it on clear parts.  It does stink a bit though!  However, for non-clear parts, it's a dream (if you don't mind a smell whilst working).  Girls use it to clear their fingernails though, so, not too bad.
    July 2011
Posted by BBAT222 on Monday, October 10, 2011 5:21 PM
Well Mike where the auto primer caused the enamel to crack and split it also scared the plastic.  Am I dead in the water or is there some kind of hope?  Buddy B.
    August 2011
Posted by GreenThumb on Monday, October 10, 2011 5:56 PM
There is nothing that can't be fixed. Wink
What is scarred and where?
    July 2011
Posted by BBAT222 on Monday, October 10, 2011 9:11 PM
The bottom of the wings and the fuselage.  I've got the paints off, but where the enamel shrank and split, it left spider web like scares on the surface of the bottom.  A lot of sanding, but I'm afraid I'll lose a lot of detail. Really smooth.     Buddy B.
    August 2011
Posted by GreenThumb on Monday, October 10, 2011 9:42 PM
Can you prime over it and cover the damage?
    July 2011
Posted by BBAT222 on Monday, October 10, 2011 10:33 PM
Well Mike the mention of primer gives me the hives, but I think your right.  I think I'll pencil back in the details with some scribing. Beer Here is to no finger hash!Tongue Tied  G-night and thanks to all.  Buddy B.
    April 2009
Posted by Cadet Chuck on Monday, October 10, 2011 10:43 PM
You can buy NON-ACETONE nail polish remover.  Cheap!  While I haven't tried removing paint with it, I find it works well for thinning and removing Squadron putty, before it dries.  And it won't attack the plastic.
