I have read a bunch of things about using a gloss coat, many times being Future, to give decals a good surface for adhesion and then a final coat of flat or clear for protection and a base for washes. What gets confusing is what can or cannot go on top of the other.
So if I am sticking with the MM line of paints, that would have me putting a lacquer based gloss over my MM flat enamels and then a MM lacquer flat over top of the gloss once the decals are down. Am I going to have a problem with one lacquer coat over another? If so should my flat coat be the MM acrylic clear or the Future clear?
I am sure this gets asked a bunch but I couldn't quite find a clear answer in searching the forums.
Thanx!!
John
