MM auto lacquer question
    December 2011
Posted by TroyH on Friday, January 6, 2012 3:56 PM
possible stupid question.
I'm using MM auto lacquer spray for the first time on a custom 1940 ford 4-door to represent my father-in-laws hot rod he just built. should i wet sand it before i clear coat? also it has a couple of imperfections that wet sanding would hopefully get rid of.
thanks
    January 2011
Posted by stymye on Saturday, January 14, 2012 9:38 AM
If it's the metalflake spray colors  , I would be very careful sanding , it exposes the metallic particles in an odd way
I have had the same thing happen with the metalflake paint with blemishes that were too obvious.
I just stripped and resprayed, because sanding actually made it worse.
depends on the color
Posted by Don Stauffer on Saturday, January 14, 2012 9:41 AM
If it has imperfections, especially dust, I'd sand it.  Use very fine paper- 1000, 1200 or something.  But frequently glosscoating dust particles makes them look even worse.
    September 2011
Posted by OMCUSNR on Sunday, January 15, 2012 10:59 AM
Try using an auto detailer's clay bar.  It's what they use just prior to waxing / polishing to take out surface imperfections.
Reid
Grumman Iron Works Fan.
"Don't sweat the small stuff.  And.... it's ALL small stuff, until you hear INCOMING!!!!!!"
Posted by jhande on Monday, January 16, 2012 10:29 PM
Well it depends...
It the paint layer is thick and the dust set deep and not much in the way of fine molded detail; wet sand (also try a coffee filter).
If the paint layer is thin, lots of molded detail, dust on the surface; try rubbing it out using rubbing or polishing compound (Crest toothpaste might be abrasive enough).
Either way... rub gently!
-- Jim --
"Put the pedal down & shake the ground!"
