clear coats
    January 2012
clear coats
Posted by JesniF-16 on Saturday, January 21, 2012 12:32 PM
Hello modelers,
I was wondering if I should use a gloss clear in a rattle can for finishing, or would it be better to buy a clear coat to spray with my airbrush? I tried using future on an old model, but I just don't like the results.  It doesn't spray on smooth and it seems I have to use way too many coats as it fills in the panel lines and everything.
So anyway, I don't want to lose the fine detail before I put a panel line wash and decals on my model. Is the testor's gloss and flat for the airbrush any good?
Heavy metal welder by day, light plastic welder by night
    November 2008
Posted by Wabashwheels on Saturday, January 21, 2012 12:58 PM
Frankly, I'll use Krylon Clear Gloss for the decal coat and Krylon Clear Flat for the seal coat.  I've been happy with the results.  Rick.
Posted by Tojo72 on Saturday, January 21, 2012 1:10 PM
Depends,if yoy clear coat in enamel,then you must wash and weather in acyrilic,if you clear coat with acrylic,then you must use enamels or oils to weather.
Just don't weather with the same type of medium that you clear coat with.
