Can you mix Tamiya and Gunze Mr. Color?
    June 2010
Posted by DoogsATX on Monday, January 30, 2012 1:03 PM
Well can you? I thin them both with the same thinner...so in theory?
On the Bench: 1/32 Trumpeter P-47 | 1/32 Hasegawa Bf 109G | 1/144 Eduard MiG-21MF x2
On Deck:  1/350 HMS Dreadnought
    April 2005
Posted by carsanab on Monday, January 30, 2012 1:20 PM
I tried to use tamiya thinner with it...became a nice clump of goo....I wouldnt mix them...although the Mr Color thinner takes EVYTHING off....
 Photobucket
    June 2010
Posted by DoogsATX on Monday, January 30, 2012 1:47 PM
carsanab
Which thinner? I've thinned Gunze with Tamiya lacquer thinner before with no problem (the stuff seems very similar to Gunze lacquer thinners), but I could imagine X-20A having issues.
    April 2005
Posted by carsanab on Monday, January 30, 2012 3:59 PM
yeah I used the x-20....the paint turned into little clumps in the thinner....I wasnt sure what the Mr Hobby was Laq or acrylic...I mean everything but the numbers are in japanese....Bang Head and Mr Color label,,,,..
 Photobucket
    March 2010
Posted by Nathan T on Monday, January 30, 2012 4:09 PM
No...! You CAN mix Mr. Hobby aqueous with tamiya, works good, although I never really need to. Mr. Color solvent based stuff is its own deal, doesn't mix well with anything but its own kind...doesn't seem to mix well with Model Master enamels even...
    March 2010
Posted by Nathan T on Monday, January 30, 2012 4:16 PM
I wasnt sure what the Mr Hobby was Laq or acrylic.-
Its both. Acrylic lacquer. Acrylic just means the type of binders/polymers that  hold the pigments together..(I think)Its solvent based(strong) lacquer..thats why the Mr. Color thinner took all your paint off.
    April 2009
Posted by Cadet Chuck on Monday, January 30, 2012 4:38 PM
Another example of why ALL manufacturers need to clearly label their containers as to what the stuff is, in there!  If in doubt, I mix up a test batch and see what brews up.
    April 2005
Posted by carsanab on Monday, January 30, 2012 4:48 PM
Cadet Chuck
it is labled.....but in japanese....
 Photobucket
    April 2009
Posted by Cadet Chuck on Monday, January 30, 2012 8:56 PM
Ah-So!
    August 2005
Posted by Phil_H on Monday, January 30, 2012 11:15 PM
DoogsATX
Up to a certain point, you probably can. It is (in a limited way) possible to mix Tamiya acrylic and enamel (yes, they do make enamels) using Tamiya lacquer thinner as a common thinner, but there is no compelling reason to.
The only way to know is to try it and see if it works.
