How to paint fuselage bands?
    February 2011
Posted by Reasoned on Thursday, February 2, 2012 6:56 PM
How would you go about painting the two white bands on the Val fuselage?  First paint a wide white band, tape over with two Tamiya tape pieces, then shoot top coat grey, remove tape.  Or shoot top coat grey, tape two stripes shoot the white, or other ideas?
Science is the pursiut of knowledge, faith is the pursuit of wisdom.  Peace be with you.
On the Tarmac: 1/48 Revell P-38
In the Hanger: A bunch of kits
    February 2011
Posted by randypandy831 on Thursday, February 2, 2012 6:57 PM
white first then mask off and spray overall color.
tamiya 1/48 P-47D $25 + shipping
tamiya 1/48 mosquito $20+ shipping
hobby boss 1/48 F-105G. wings and fuselage cut from sprue. $40+ shipping.
    February 2011
Posted by Reasoned on Thursday, February 2, 2012 8:53 PM
That's how I was leaning, figured it would get the straightest lines.
    August 2007
Posted by some assembly required on Monday, February 6, 2012 10:02 PM
i would make sure to burnish the tape edges right before you shoot the grey ,mist a sealer coat to help seal the edge and shoot straight down onto the tape at a 90deg. angle.  this helps keep paint bleed to a minimum. i get the best results using these tech. good luck and post some pics of your Val!!
    February 2011
Posted by Reasoned on Tuesday, February 7, 2012 10:55 AM
Will do, thanks for the pointer.
    March 2006
Posted by TD4438 on Tuesday, February 7, 2012 11:10 AM
This worked for me.
Posted by VanceCrozier on Tuesday, February 7, 2012 11:14 AM
If I was weathering it, and using straight white, I'd be tempted to put the white over the gray just to reduce the contrast a little.
On the bench: Airfix 1/72 Wildcat; Airfix 1/72 Vampire T11; Airfix 1/72 Fouga Magister
    February 2011
Posted by Reasoned on Tuesday, February 7, 2012 11:23 AM
VanceCrozier
Yeah I hadn't thought about that, the stark difference from the white to grey.  Since this is a PH Val, it has been said those have little weathering due to this being their first real combat action.
    March 2007
Posted by bondoman on Tuesday, February 7, 2012 11:27 AM
I do the band color first, then tape it over. If you do it the other way around, then you have to mask the rest of the a/c to prevent overspray. Not a big deal, but more work.
    September 2011
Posted by OMCUSNR on Tuesday, February 7, 2012 9:27 PM
I guess I'm old school...
I always start with the lightest color first, and get progressively darker.  So I'd start with the white & mask it.
Reid
Grumman Iron Works Fan.
"Don't sweat the small stuff.  And.... it's ALL small stuff, until you hear INCOMING!!!!!!"
