Opinions on Vallejo Primer
    April 2011
Posted by Unreality on Tuesday, February 14, 2012 1:49 AM
I've tried the basic grey on 2 models. On one model it worked fine (stayed down, didn't lift with masking tape). The other...not so much. It pealed off as soon as I picked it up.
I'm curious what everyone's thoughts are on these primers. Likes/dislikes?
BTW: I ended up grabbing my old spray can of Color Place primer to redo the "not so much" model.
Action Fleet Unlimited: Star Wars models, customs, toys, techniques, and scale lists (with a few non-SW models thrown in)
Cheers
    April 2004
Posted by Jon_a_its on Tuesday, February 14, 2012 5:58 AM
Love  the stuff , now available lots of armour colours , but since it stuck to one model & not the other, I suspect that the latter may have been a bit greasy, & wasn't clean?
East Mids Model Club 32nd Annual Show 2nd April 2023
 http://www.eastmidsmodelclub.co.uk/
Don't feed the CM!
    April 2011
Posted by Unreality on Tuesday, February 14, 2012 3:49 PM
That's a distinct possibility. I know I rinsed the first one with Windex and water. The second one (the one the messed up), I can't remember if I used both or just water.
Did you experience the same effect when you didn't clean it well?
Thanks by the way.
Cheers
    March 2010
Posted by Hercmech on Tuesday, February 14, 2012 3:55 PM
I have had the same thing happen. But since I don't wash my kits I am sure that had something to do with it. More oils from kit to kit.
13151015
    February 2011
Posted by gunner_chris on Wednesday, February 15, 2012 9:15 AM
I've only used the colour place grey spray, but all this talk of Vallejo primer has sparked my interest.  I noticed Redleg used it on his 8" howitzer.
Not to hijack the thread - but do you thin it before airbrushing?
    March 2010
Posted by Hercmech on Wednesday, February 15, 2012 9:29 AM
gunner_chris
When I sprayed it using my "big" nozzle (.5 Iwata setup) I did not thin it...but when I sprayed it through my other AB I did thin it a little.  It is pretty thin already so you may not need to.
13151015
Moderator
    April 2006
  • From: my keyboard dreaming of being at the workbench
Posted by Aaron Skinner on Wednesday, February 15, 2012 9:33 AM
I've had good experiences using Vallejo primer. It airbrushes well and gives a great surface for paint. Like all acrylics, the surface has to be clean. I usually clean the model with a mild dish detergent mix, the wipe the surface with Testors (formerly Polly S) Plastic Prep — I don't think the model can be too clean.
Cheers, Aaron
Aaron Skinner
Editor
FineScale Modeler
    January 2009
Posted by Griffin on Wednesday, February 15, 2012 2:01 PM
I've had problems with the Vallejo primer but there's a couple factors that are most likely to be blamed (mostly user error):
  1. I thinned with water,
  2. I was a first time air-brusher.
I would like to try it again. I don't think it was oil or release agent - I had washed with dish detergent and water.
What's the best way to thin this primer for AB'ing? What pressure should I be using?
Moderator
    April 2006
Posted by Aaron Skinner on Wednesday, February 15, 2012 2:07 PM
Griffin
Griffin,
I used Vallejo thinner, but it doesn't take much. Pressure's a little tougher, but I think I was spraying at 20-25psi.
Cheers, Aaron
Aaron Skinner
Editor
FineScale Modeler
    August 2006
Posted by Brian D. on Wednesday, February 15, 2012 4:52 PM
I have used their Russian Green primer.  It has gone on smooth as silk for me.  When I airbrush it I usually put 1 or 2 drops of Vallejo thinner.   I also prep my models by cleaning them with Windex.
    January 2009
Posted by Griffin on Wednesday, February 15, 2012 8:12 PM
Thanks Aaron and Brian for the help.
BTW Aaron, I'm reading your new book. I'm learning lots! Yes
Moderator
    April 2006
Posted by Aaron Skinner on Thursday, February 16, 2012 10:31 AM
Griffin
Griffin,
Glad you like it.Embarrassed
Aaron Skinner
Editor
FineScale Modeler
