Shopping For A New Respirator
Posted by djrost_2000 on Thursday, February 23, 2012 3:57 PM
Was looking for replacement cartridges for my respirator and they are mighty pricey.   Can anyone lead me to one that doesn't charge over $50 for cartridges.  I don't want to skimp on safety but I do have a budget.  Also what type of cartridge?
Dave
    January 2009
Posted by Griffin on Thursday, February 23, 2012 8:33 PM
I use one of these:
http://www.grainger.com/Grainger/3M-Respirator-Assembly-3WXU8
With these Cartridges:
http://www.grainger.com/Grainger/3M-Particulate-Filter-4JG27?cm_sp=IO-_-IDP-_-BTM_BTB05209020&cm_vc=IDPBBZ2
I'm fairly certain these are the models. I know I can abate asbestos with them though.
Posted by djrost_2000 on Friday, February 24, 2012 1:34 PM
Griffin, thank you for the reply.  I see that it is a particulate filter, but does it filter out the fumes from airbrushing lacquer thinner?
Thank you,
Dave
    January 2009
Posted by Griffin on Friday, February 24, 2012 2:00 PM
I brush with acrylics but when I clean with simple clean and windex, I can't smell a thing. You should go to a safety supply dealer and ask them to be certain.
    June 2006
Posted by MaxPower on Friday, February 24, 2012 6:21 PM
Hi,
That is a particulate cartridge and not what you are looking for. You want a chemical cartridge. They will filter out volatile organic compounds(VOCs) and vapors. This type of cartridge will filter out dust and heavy aerosol particulates with a hepa filter but will contain typically activated charcoal or some type of chemical media to remove vapors. Unfortunately these aren't super cheap. The ones I use are $35 each and obviously I need 2 at a time. I'm lucky though I knick them from work.
A tip for using these cartridges. The active charcoal will constantly absorb whether you are wearing it or not so take it off the mask and store it in a zip-lock bag while not in use they will last longer.
To really protect yourself a particulate mask wont work, you're still getting the vapor and I bet if you wore that and sprayed lacquer you can smell it through the mask.
    September 2011
Posted by OMCUSNR on Friday, February 24, 2012 7:19 PM
This cartridge:   http://www.grainger.com/Grainger/3M-Organic-Vapor-Cartridge-6AM37?Pid=search
Would work with the series 6000 respirator @  Grainger, for VOC's
Reid
Grumman Iron Works Fan.
"Don't sweat the small stuff.  And.... it's ALL small stuff, until you hear INCOMING!!!!!!"
    January 2009
Posted by Griffin on Friday, February 24, 2012 8:06 PM
Thanks guys - It looks like I'll be shopping for new filters too. Dead
    April 2009
Posted by Cadet Chuck on Friday, February 24, 2012 9:14 PM
I found a good NIOSH vapor respirator, made by 3M, for about $30 at Lowe's.  The filters are dated and good for about 4 years.  I can't smell a thing, no matter what I am spraying, when I wear it.
Posted by djrost_2000 on Saturday, February 25, 2012 12:26 PM
It looks like the filters I was looking for are no longer commonly available so I bought another respirator that looks a lot like my old one with filters for organic compounds or vapors and it has particulate filters as well.  With my old respirator which was for organic/particulate I couldn't smell a thing even when running lacquer thinner through the airbrush.
I'm also curious as to how long the typical organic filter will last.  The way I do it, I buy new filters if I start to detect an odor when airbrushing.
Dave
    February 2011
Posted by Reasoned on Saturday, February 25, 2012 1:13 PM
I'm sure glad somebody looks into what they breath, I wish it were me.
Science is the pursiut of knowledge, faith is the pursuit of wisdom.  Peace be with you.
On the Tarmac: 1/48 Revell P-38
In the Hanger: A bunch of kits
