I have such a buildup of paint on the walls of my spray booth that the vibration from the fan is causing flaking of dust and pieces of paint that falls on the model :-( I realize I have been making a big mistake. When I clean the nozzle of a rattle can I aim the can at the sides, so that I maximize the life of the filter. But the furnace filters I use in the booth only cost about three bucks a piece! I am finding the difficulty of getting the spray booth sides clean far outweighs any savings from a slightly longer life for the filter!
I will now clean the nozzles by spraying directly towards the filter, and if I get the walls clean enough to stick down Contact paper, I will coat the booth with that so removing any paint on walls will be easier!
The biggest problem is the Krylon primer I use. It is very full bodied, and covers scratches and sanding marks great! But boy it sure builds up fast in the spray booth.
