Airbrushing pressure changes
    August 2012
Posted by JMorgan on Thursday, August 2, 2012 7:22 PM
Does anyone know what causes the pressure to change (right after you press the trigger) from low for a split second to higher and steady the next? The paint I used was thin and hte airbrush used was a Paasche H external mix. Thank you!
    April 2004
Posted by keilau on Friday, August 3, 2012 7:19 AM
JMorgan
Your description fits the working of a poorly designed pressure regulator and its pressure port.
For the use of airbrush, the pressure setting provide a measure of the driving (pumping, pushing air) potential. It is most accurate to measure the static pressure when there is no flow. If your compressure has a diaphram type regulator, the knob will privide uniform, multiple turn adjustment that is linear in action. The pressure port should be a very tiny, 1/16" or so, hole connecting to the pressure gauge. The pressure reading may drop slightly, 0.2-0.5 psi when you push the trigger. The reading should be steady.
Some of the cheap regulator use a simple orifice or a gaping hole of 1/4" or larger in the pressure port or both to save cost. Effectively, the gauge sees partial dynamic, partial static pressure. It may result in what you see in your compressor. Because the dynamic pressure is NOT a constant of the pressure setting, the user lose the reference value.
A perfect pressure reading will require a 2-stage regulator like those you see in a torch setup. But it is too expensive and not really necessary for a hobby compressor. I have an old regulator from TCP Global from 8-10 years ago, it works very well. I bought a new regulator at Ebay out of couriocity last year, and the adjustment was coarse and the reading fluctrates. Both costed less than $20.
Below is a picture of my old, good working regulator. I replaced the pressure gauge with a large face one of 60 psi full scale. The setup allows me very accurate and fine adustment of pressure when experimenting with new paint and mixing ratio.
    October 2008
Posted by P mitch on Friday, August 3, 2012 8:09 AM
You dont say what type of compressor your using so I'm going to give you a general idea of what can cause the problem. The air hose which connects the compressor to the airbrush can act as a miniature tank for the air. If you have a regulator on the hose when the air in the hose reaches the pressure you selected on the regulator it will be held at that pressure. When you first press the trigger on your airbrush this will let some air out so the pressure will drop a little. At this point the pump will start again forcing air into the hose, as the trigger is open it will get a little to much air then the regulator will catch up and get the pressure back to what you selected.
I know it sounds a bit complicated but I can say it happens with mine all the time, what I do as I have a duel action brush is let the air run for a few seconds then start the paint so the "pulse" of air your talking about is gone.
Hope that helps
Phil
"If anybody ever tells you anything about an aeroplane which is so bloody complicated you can't understand it, take it from me: it's all balls." R J Mitchell
    August 2012
Posted by JMorgan on Saturday, August 4, 2012 12:15 PM
Will the same phenomena occur with a compressor/tank combo that you mentioned?
    October 2008
Posted by P mitch on Saturday, August 4, 2012 12:20 PM
It can a little but its such a small drop I wouldn't worry about it, I've never found it to be a problem and I'm sure better people with an airbrush than me would agree
    August 2012
Posted by JMorgan on Saturday, August 4, 2012 12:25 PM
Thanks for your answer. I'll look into another compressor/tank combo. Mine (Campbell/Hausfield) you cant even adjust below 20 psi.
    August 2007
Posted by DUSTER on Saturday, August 4, 2012 11:37 PM
JMorgan
Sounds like you have a shop type compressor which is designed to a different job type category.
The my usual air brush pressures are 20psi and below.(though there are times of higher pressures for specific painting requirements)  so the style of compressor you are using is expected to operate at 20+ psi which gives you a small window of compatibility with your air brush.
So don't give up get a smaller compressor if you have the $$ for it or learn to work around you current one by knowing what it going to do and be ready for it
Regardless keep trying and things and knowledge will get better
Steve
    March 2012
Posted by 01JeepXJ on Sunday, August 5, 2012 10:41 AM
You have a GOOD compressor. Try this if you haven't. Drill a pin size hole in the hose adapater-the brass reducer from the air outlet that you screw your a.b. hose on. This will act as a pressure release valve/help mantain a constant p.s.i. reading. I can adjust my p.s.i. down to almost "0" reading on my guage.
I do always give a short burst from my a.b. before I paint-just to make sure.
Never try to teach a pig to sing. It's a waste of time and only annoys the pig.
