Badger Krome vs Iwata HP-CS
    September 2012
Posted by WutDaFunk on Saturday, October 6, 2012 2:26 AM
I'm torn between the Krome and the Iwata HP-CS for my first airbrush.
I'll mainly be base coating and pre-shading with enamels, so the .21 needle set wouldn't be used as much as the .33 set. This leads to my first question:
In case I lose/break the tip/needle, which .33 parts does the Krome use, is it the ones that come with the Rage?
Does the Krome come with the self-centering nozzle feature, and is this even a big deal?
Which has better paint atomization?
Last, compared to the CS, how easy is it to clean the Krome?
I know Badger has great customer service, and cheaper parts. I'm really leaning towards the Krome, but if it's easier to clean and maintain the CS, I'll probably go for the CS.
I'm open to any suggestions.
    October 2008
Posted by Don Wheeler on Saturday, October 6, 2012 10:35 AM
The .33mm set is the same as the Rage.
The Krome nozzle is self centering, but it is tiny.
Both atomize just fine.
The tiny nozzle means you have to be a little more careful cleaning the Krome.  Both are easy to clean.
The Krome has a needle limiter, which can be handy.
Don
https://sites.google.com/site/donsairbrushtips/home
A collection of airbrush tips and reviews
Also an Amazon E-book and paperback of tips.
    April 2004
Posted by keilau on Saturday, October 6, 2012 10:55 AM
Despite the small nozzle size, the Krome and the Iwata CS has the same linear flow angle. So there is little difference between the 0.21 mm and 0.35 mm nozzle in term of atomization and overspray. I have not tried the Krome with the 0.33 needle, but it does not sound like a good idea.
I have Hobby Lobby Store locally, therefore, I can get Iwata CS parts cheaper than Krome parts. (No shipping cost.)
Both are wonderful airbrush for modeling. You cannot go wrong with either. I have both, but use the CS more often. It is mostly a familiar factor issue because I got the CS much earlier. The bigger physical size of the CS nozzle is a plus when I have to take it apart for more thorough cleaning occasionally.
    September 2012
Posted by WutDaFunk on Friday, October 12, 2012 4:41 AM
Very good point on the CS nozzle, also, does Hobby Lobby carry the .35 nozzle? Why would the .33 set be a bad idea?
Sorry for the late response, I've been having connection problems.
    August 2009
Posted by denstore on Friday, October 12, 2012 2:05 PM
I really can't see what would be bad about the 0.33mm setup? Can you develop that thought?
Better an airbrush in the hand, than ten in the car....Stick out tongue
    September 2012
Posted by WutDaFunk on Friday, October 12, 2012 9:01 PM
That's what I'm trying to figure out. lol
    June 2010
Posted by montague on Saturday, October 13, 2012 1:23 AM
I have had both airbrushes. The Iwata is easier to use and clean but will not do the fine work the Krome will. If you are experienecd, the Krome is a far better detail brush. The Iwata is a better all around brush. I Have my Krome with the .22 set up and NEVER change it! I use a Badger Patriot 105 with the fine set up ( about .5 or below) for more general coverage work. You can do all airbrushing with the Krome at .22, It just takes longer. The Iwata is capable for a wide range and master of none. The Krome is a Great detail airbrush at less cost and lower parts cost also.
    April 2004
Posted by keilau on Saturday, October 13, 2012 6:40 AM
WutDaFunk
Hobby Lobby carries both the Iwata Eclipse series 0.35 and 0.5 mm nozzle/needle/crown parts. As expected, the 0.35 mm parts are more expensive. It is a good saving when using their 40% off coupon and avoiding paying for shipping.
denstore
The Krome 0.21 mm needle has a 6 degrees linear flow angle which is very good for general purpose work, but not as fine as that of the SOTAR 20/20. I do not see what can be gain from changing to the 0.33 mm needle which has a double taper at the end and a larger linear flow angle. See Don Wheeler's review of the Badger Rage for more detail.
I have not used the 0.33 mm setup with the Krome and am not saying that it is bad. I am saying that there is nothing to gain from paying the extra parts to make the change from the 0.21 mm setup. Sorry that I did not make my point clearer in my earlier post.
    September 2012
Posted by WutDaFunk on Saturday, October 13, 2012 11:31 PM
keilau
WutDaFunk
denstore
I think I've decided on the CS, because it's easier to clean and I also have a local Hobby Lobby for parts.
The Krome does come with a .33 needle set included with the .21 set now,  so switching is free.
    August 2009
Posted by denstore on Sunday, October 14, 2012 6:33 AM
Didn't know about the double taper. I really can't see the point in having them at all. I've never had any problem with normal tapered needles, not even silly long taper needles as some of the older Rich's.
    April 2004
Posted by keilau on Sunday, October 14, 2012 9:21 AM
denstore
You will not see double taper on any manufacturer's top of the line models. Some use double taper on the lower priced models.
    August 2009
Posted by denstore on Sunday, October 14, 2012 1:57 PM
I really didn't think that they would use it on models like the Rage. Isn't the Renegade series supposed to be their new pro series?
    September 2012
Posted by WutDaFunk on Sunday, October 14, 2012 4:07 PM
keilau
denstore
Does the CS have a double tapered needle?
    August 2009
Posted by denstore on Sunday, October 14, 2012 6:09 PM
No, I don't think any Iwata has a double taper. At least not any I've encountered.
    February 2011
Posted by randypandy831 on Sunday, October 14, 2012 7:17 PM
both are awesome. comes down to personal preference.
tamiya 1/48 P-47D $25 + shipping
tamiya 1/48 mosquito $20+ shipping
hobby boss 1/48 F-105G. wings and fuselage cut from sprue. $40+ shipping.
    September 2012
Posted by WutDaFunk on Sunday, October 14, 2012 7:35 PM
I kind of agree with Don Wheeler's Krome review though, it's kind of "overkill" for a first airbrush...
    October 2008
Posted by Don Wheeler on Sunday, October 14, 2012 7:44 PM
The Iwata Revolution HP-CR has a double taper.   See photo on this page.  So does the Grex Genesis XBi.  The Sotar medium needle has a tiny secondary taper right on the end.
A double taper on a larger needle allows finer trigger control at the beginning of the pull.
Don
    October 2008
Posted by Don Wheeler on Sunday, October 14, 2012 8:00 PM
WutDaFunk
I think it depends on the individual.  If they take the time to learn how to take care of it, it's a fine airbrush.  But, any airbrush with a 0.22mm nozzle is going to be more fragile and require more careful thinning.  And, most users don't really need that narrow a spray angle.  The 0.33mm nozzle gives a considerably wider pattern, but it is still very tiny and delicate.
Don
Posted by Wingman_kz on Sunday, October 14, 2012 8:38 PM
The double taper really isn't noticeable on a needle .050 or below. There's more of a taper on the CR needle than there is on the 105 Patriot needle, both are listed as .050mm, but I really don't notice that the taper is there when spraying. Move up to the .070 needle like the Badger 360 or Anthem use and I definitely notice the transition. To me at least, that needle/tip combination is a little touchy when you're trying to spray the finest pattern possible with it. You can with practice but one wrong move and you're at a much wider spray. And for what I use that needle for, that's fine. Whether it's in my 105 or 360, it's for general coverage or primer.
Originally there was a slight double taper on the fine needle in my Sotar that's listed as .021mm. But after bending the tip a couple times, straightening and polishing it isn't there anymore. When it was there you coldn't tell it. Or, I couldn't. Not much difference between the needle and tip in a Sotar and a Renegade.
Let's face it, there's a learning curve with whatever brush you start with. And when/if you get another, you'll have to learn again. It's true that the smallest needles and tips will be more finicky as far as paint mix and pressure but once you learn that, you can do anything. Maybe something in the mid-range would be a better starting point but the Krome comes with an .033 set-up and from what I understand(no, don't have one) it will flow a good bit of paint. With a CS you have a choice that doesn't require any tools to swap. Same with a 105, 155 or 360 Badger. They can all use the same parts and require no tools unless you want to take apart the airvalve. Personally, I get tired of swapping needles and tips and regulators around real quick, that's one reason for multiple brushes.
Tony
Posted by Wingman_kz on Sunday, October 14, 2012 8:42 PM
I'm with Don. And your post wasn't showing when I started writing Don. Watching football too. :-)
Tony
    August 2009
Posted by denstore on Monday, October 15, 2012 4:40 AM
But why? They could just let it protrude a bit? When doing a bit of calculation in my head, a 6 degree needle would protrude about 4,7mm from a 0.5mm nozzle, which might be a bit long, but only slightly over 3mm on a 0.33mm nozzle. I can see the point of having double taper on large nozzle setups, but not on anything less than 0.5mm.
    October 2008
Posted by Don Wheeler on Monday, October 15, 2012 11:27 AM
I think it's a balance of geometries.  As you noted, an airbrush needle typically extends about 3mm past the nozzle.  If you go much further, you might have air turbulence which could affect spray pattern.  It's also a function of trigger and rocker design.  Usually, full travel of the trigger will move the needle from fully closed to fully open.  Any more would be wasted.  It makes sense to keep the same trigger assembly in an airbrush with different nozzle sizes.
I think you will find that double tapers are mostly used in larger sizes.  In the Paasche VL, for instance, the medium and large needles have a double taper, but the fine doesn't.  In the Talon, only the large needle is double tapered.
Don
    August 2009
Posted by denstore on Monday, October 15, 2012 5:17 PM
I have been checking my airbrushes tonight. Non has a double taper, but then, the largest nozzle size I have is 0.4mm. But the three 0.3mm or the 0.4 airbrushes ought to be similar enough to the Rage 0.33 to prove that it isn't any real need of making it double tapered.
Trigger stroke length must depend on construction and physical size as well. Placing the pivoting point further down from the needle ought to make it possible to build for a longer stroke.
    October 2008
Posted by Don Wheeler on Monday, October 15, 2012 5:35 PM
Badger, like most manufacturers, standardizes many parts to keep cost down.  The Rage and Krome trigger mechanisms are basically Thayer & Chandler parts.  They seem to work pretty well.  People who need finer lines can easily convert to the smaller nozzle set.
Don
    August 2009
Posted by denstore on Monday, October 15, 2012 5:50 PM
Do the needles for the 0.33 and the 0.21mm have the same angle on the first taper? I.e, the only one on the 0.21 needle.
    October 2008
Posted by Don Wheeler on Monday, October 15, 2012 8:15 PM
denstore
You can see a picture of them side by side in my Krome review.
Don
    April 2004
Posted by keilau on Monday, October 15, 2012 8:23 PM
denstore
The Badger Renegade Velocity superfine or Krome use Badger Parts # R-003 needle and the Rage uses Badger Parts # R-004 needle. Based on published data, the linear flow angles are 6.0 and 6.5 degrees respectively. Both are good for general modeling tasks.
    June 2010
Posted by montague on Monday, October 15, 2012 11:32 PM
Getting this picky is really useless. It will never be discerned by the un aided eye. Buy the Krome, Put in the .22 and know that other then maybe a Harder and Steenbeck infiniy, it is as small as you can go.
    August 2009
Posted by denstore on Tuesday, October 16, 2012 5:14 AM
My thought was that if the Rage needle has the same angle taper in the first taper section as the Krome, you should be able to use a Krome needle with 0.33mm nozzle.
Since you have both, you could try it, if it would be of interest to you.
I'm always looking for new combinations to adapt my airbrushes to my own needs. "Problem" is that most high end airbrushes already are tuned to what the manufacturer consider be the best setting. But I believe that they sometimes donĀ“t want to compete with their own products by making it too easy to adapt to other specifications. The Iwata Revultions are a good example. When they first arrived at the scene, Iwata said that the CR wouldn't convert to 0.3mm. People played around with it, and came to the conclusion that the 0.3mm needle and nozzle setup for the BR would fit.
Today, there are "conversion kits" available as spare parts for doing this. And considering that the same kind of conversion can be made on the BR, but to both 0.2mm and 0.5mm, my guess is that they all use needles honed with the same angle, and because of that fit with either 0.2, 0.3 or 0.5mm nozzles. So why isn't Iwata having this in their information? Probably because they rather sell one of each of these airbrushes, or maybe even more important, want people that are looking for better detailing capabilities to buy the HP-B instead of buying a 0.2mm setup for their CR.
On the other hand, just by changing the needle and nozzle on a CR to 0.2mm doesn't make it an ideal detailing airbrush. It is too front heavy, too long, and probably has a bit too high angle needle taper to really compete with the HP-B.
    April 2004
Posted by keilau on Wednesday, October 17, 2012 7:37 AM
denstore
A long, sharp, single taper needle can get damaged easier. Chopping of the slender tip by using a double taper is mostly a cost saving measure to the manufacturer. The compromise is a less precise spray pattern. It is less a concern with larger nozzle size.
I found that Iwata user are usually less concerned about the needle damage because the needle is more springy, thus less prone to damage or bending. Some knock-off needles are sharp with a single taper. But it is no favor to the user because it does not keep the shape very well.
I have 2 Powercat and one Neo for Iwata knock-off. So I know their needle quality first hand.
